Smooth transitions in texture-based simplification, Computers & Graphics, vol.22, issue.1, pp.71-81, 1998. ,
Automatic image placement to provide a guaranteed frame rate, Proceedings of SIG- GRAPH '99, 1999. ,
Filtering, clustering and hierarchy construction: a new solution for raytracing complex scenes, Computer Graphics Forum, p.95, 1995. ,
A general method for preserving attribute values on simplified meshes, IEEE Visualization '98, pp.59-66, 1998. ,
Appearancepreserving simplification, Proceedings of SIGGRAPH '98, 1998. ,
The delta tree: An object-centered approach to imagebased rendering, 1996. ,
Navigating static environments using image-space simplification and morphing, ACM Symp. Interactive 3D Graphics, 1997. ,
Approximation Algorithms for Bin-Packing ??? An Updated Survey, pp.46-93, 1997. ,
DOI : 10.1007/978-3-7091-4338-4_3
GAPS: General and automatic polygonal simplification, ACM Symp. Interactive 3D Graphics, 1999. ,
Segmentation of range data into planar and quadratic patches, Proceedings of IEEE Conf. on Computer Vision and Pattern Recog- nition, 1983. ,
Surface simplification using quadric error metrics, Proceedings of SIGGRAPH '97, 1997. ,
Hierarchical face clustering on polygonal surfaces, ACM Symp. Interactive 3D Graphics, 2001. ,
Point sample rendering, Eurographics Rendering Workshop, 1998. ,
Survey of polygonal surface simplification algorithms, Tech. rep, 1997. ,
Approximation Problems for NP-hard Problems, 1997. ,
Superfaces: Polygonal mesh simplification with bounded error, IEEE CG&A, vol.16, issue.3, pp.64-77, 1996. ,
Adaptive Texture Maps, Proc. SIGGRAPH/EG Graphics Hardware Workshop '02, pp.7-15, 2002. ,
The use of points as a display primitive, 1985. ,
Image-driven simplification, In ACM Transactions on Graphics, vol.19, pp.204-241, 2000. ,
Model simplification using vertexclustering, ACM Symp. Interactive 3D Graphics, 1997. ,
View-dependent simplification of arbitrary polygonal environments, Proceedings of SIGGRAPH '97, 1997. ,
Visual navigation of large environments using textured clusters, ACM Symp. Interactive 3D Graphics, 1995. ,
Hierarchical image-based rendering using texture mapping hardware, Eurographics Rendering Workshop, 1999. ,
Interactive volumetric textures, Eurographics Rendering Workshop, 1998. ,
Relief texture mapping, Proceedings of SIGGRAPH, 2000. ,
Surfels: Surface elements as rendering primitives, Proceedings of SIGGRAPH, 2000. ,
Efficient warping for architectural walkthroughs using layered depth images, IEEE Visualization '98, 1998. ,
Progressive simplicial complexes, Proceedings of SIGGRAPH '97, 1997. ,
Compositing digital images, Proceedings of SIGGRAPH '84, 1984. ,
Simplification, lod and multiresolution -principles and applications, 1997. ,
Multi-resolution 3D approximation for rendering complex scenes, 2nd Conf. on Geometric Modelling in Computer Graphics, 1993. ,
Qsplat: A multiresolution point rendering system for large meshes, Proceedings of SIGGRAPH, 2000. ,
Silhouette clipping, Proceedings of SIGGRAPH, 2000. ,
A threedimensional image cache for virtual reality, Computer Graphics Forum, vol.15, issue.3, 1996. ,
Fast shadows and lighting effects using texture mapping, Computer Graphics (Proceedings of SIGGRAPH '92) 26, pp.249-252, 1992. ,
Hierarchical image caching for accelerated walkthroughs of complex environments, Proceedings of the 23rd annual conference on Computer graphics and interactive techniques , SIGGRAPH '96, 1996. ,
DOI : 10.1145/237170.237209
Layered depth images, Proceedings of the 25th annual conference on Computer graphics and interactive techniques , SIGGRAPH '98, 1998. ,
DOI : 10.1145/280814.280882
Efficient impostor manipulation for real-time visualization of urban scenery, Computer Graphics Forum, vol.16, issue.3, 1997. ,
URL : https://hal.archives-ouvertes.fr/inria-00510095
Talisman: Commodity realtime 3d graphics for the pc, Proceedings of SIGGRAPH '96, 1996. ,
Visibility-guided simplification, IEEE Visualization '02, 2002. ,
