Dynamic Canvas for Immersive Non-Photorealistic Walkthroughs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The static background paper or canvas texture usually used for non-photorealistic animation greatly impedes the sensation of motion and results in a disturbing ``shower door'' effect. We present a method to animate the background canvas for non-photorealistic rendering animations and walkthroughs, which greatly improves the sensation of motion and 3D ``immersion''. The complex motion field induced by the 3D displacement is matched using purely 2D transformations. The motion field of forward translations is approximated using a 2D zoom in the texture, and camera rotation is approximated using 2D translation and rotation. A rolling-ball metaphor is introduced to match the instantaneous 3D motion with a 2D transformation. An infinite zoom in the texture is made possible by using a paper model based on multifrequency solid turbulence. Our results indicate a dramatic improvement over a static background.
Mots clés
npr_paper.pdf (5.91 Mo) Télécharger le fichier
infinite_zoom.mov (9.04 Mo) Télécharger le fichier
infinite_zoom.mpg (3.75 Mo) Télécharger le fichier
rolling_sphere.mov (14.32 Mo) Télécharger le fichier
rolling_sphere.mpg (6.53 Mo) Télécharger le fichier
spherical_warp.mov (13.56 Mo) Télécharger le fichier
spherical_warp.mpg (6.14 Mo) Télécharger le fichier
walkthrough.mov (26.11 Mo) Télécharger le fichier
walkthrough.mpg (22.07 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00510176 , version 1 (13-10-2010)
  • HAL Id : inria-00510176 , version 1
Matthieu Cunzi, Joëlle Thollot, Sylvain Paris, Gilles Debunne, Jean-Dominique Gascuel, et al.. Dynamic Canvas for Immersive Non-Photorealistic Walkthroughs. Proc. Graphics Interface, 2003, Halifax, Canada. ⟨inria-00510176⟩
778 Consultations
268 Téléchargements
