Interactive watercolor rendering with temporal coherence and abstraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents an interactive watercolor rendering technique that recreates the specific visual effects of lavis watercolor. Our method allows the user to easily process images and 3d models and is organized in two steps: an abstraction step that recreates the uniform color regions of watercolor and an effect step that filters the resulting abstracted image to obtain watercolor-like images. In the case of 3d environments we also propose two methods to produce temporally coherent animations that keep a uniform pigment repartition while avoiding the shower door effect.
watercolor.pdf (21.59 Mo) Télécharger le fichier
static_pipeline_3d.mpeg (12.73 Mo) Télécharger le fichier
static_pipeline_photo.avi (29.29 Mo) Télécharger le fichier
temporal_coherence.avi (86.55 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
inria-00510223 , version 1 (13-10-2010)
  • HAL Id : inria-00510223 , version 1
Adrien Bousseau, Matthew Kaplan, Joëlle Thollot, François X. Sillion. Interactive watercolor rendering with temporal coherence and abstraction. International Symposium on Non-Photorealistic Animation and Rendering (NPAR), 2006, Annecy, France. ⟨inria-00510223⟩
916 Consultations
2877 Téléchargements
