Hierarchical monte carlo radiosity, Proc. 9th Eurographics Workshop on Rendering, pp.259-268, 1998. ,
Meshless methods: An overview and recent developments, Computer Methods in Applied Mechanics and Engineering, vol.139, issue.1-4, pp.3-48, 1996. ,
DOI : 10.1016/S0045-7825(96)01078-X
Global illumination of glossy environments using wavelets and importance, ACM Trans. Graph, vol.15, issue.1, pp.37-71, 1996. ,
Smoothed particles: A new paradigm for animating highly deformable bodies, Proc. Eurographics Workshop on Computer Animation and Simulation, pp.61-76, 1996. ,
Radiosity for point-sampled geometry, Proc. 12th Pacific Conference on Computer Graphics and Applications, pp.152-159, 2004. ,
Multistep scattered data interpolation using compactly supported radial basis functions, J. Comput. Applied Math, vol.73, pp.65-78, 1996. ,
Radiance cache splatting: A gpu-friendly global illumination algorithm, Proc. Eurographics Symposium on Rendering, pp.55-64, 2005. ,
Textures and radiosity: Controlling emission and reflection with texture maps, Proc. SIGGRAPH 94, pp.51-58, 1994. ,
Hierarchical higher order face cluster radiosity for global illumination walkthroughs of complex non-diffuse environments, Comp. Graph. Forum, vol.22, issue.3, pp.563-572, 2003. ,
Modeling the interaction of light between diffuse surfaces, Computer Graphics (Proc. SIGGRAPH 84), pp.213-222, 1984. ,
Wavelet radiosity, Proc. SIGGRAPH 93, pp.221-230, 1993. ,
Viewdependent precomputed light transport using nonlinear gaussian function approximations, Proc. ACM Symposium in Interactive 3D Graphics, 2006. ,
Deferred Splatting, Comp. Graph. Forum, vol.23, issue.3, pp.653-660, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00355034
R-trees: a dynamic index structure for spatial searching, Proc. ACM SIGMOD, pp.47-57, 1984. ,
A rapid hierarchical radiosity algorithm, Computer Graphics (Proc. SIGGRAPH 91), pp.197-206, 1991. ,
Direct-to-indirect transfer for cinematic relighting, ACM Trans. Graph, vol.25, issue.3, pp.1089-1097, 2006. ,
Wavelet radiosity on arbitrary planar surfaces, Proc. 11th Eurographics Workshop on Rendering, pp.161-172, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00099026
Fast, arbitrary brdf shading for low-frequency lighting using spherical harmonics, Proc. Eurographcis Workshop on Rendering, pp.301-308, 2002. ,
Wavelet radiance transport for interactive indirect lighting, Proc. Eurographics Symposium on Rendering, pp.161-171, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00379398
Radiance caching for efficient global illumination computation, IEEE Trans. Vis. Comput. Graph, vol.11, issue.5, pp.550-561, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00461512
Surfaces generated by moving least squares methods, Math. Comput, vol.37, pp.141-158, 1981. ,
Masterelement vector irradiance for large tessellated models, Proc. GRAPHITE 05, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00105660
Particlebased fluid simulation for interactive applications, Proc. ACM SIG- GRAPH/Eurographics symposium on Computer animation, pp.154-159, 2003. ,
Point based animation of elastic, plastic and melting objects, Proc. ACM SIGGRAPH/Eurographics symposium on Computer animation, pp.141-151, 2004. ,
All-frequency shadows using non-linear wavelet lighting approximation, ACM Trans. Graph, vol.22, issue.3, pp.376-381, 2003. ,
3d scattered data interpolation and approximation with multilevel compactly supported rbfs, Graph. Models, vol.67, issue.3, pp.150-165, 2005. ,
Meshless animation of fracturing solids, ACM Trans. Graph, vol.24, issue.3, pp.957-964, 2005. ,
Surfels: surface elements as rendering primitives, Proc. SIGGRAPH, pp.335-342, 2000. ,
Wavelet Projections for Radiosity, Computer Graphics Forum, vol.13, issue.2, pp.141-151, 1994. ,
DOI : 10.1111/1467-8659.1320141
A global illumination solution for general reflectance distributions, Computer Graphics (Proc. SIGGRAPH 91), pp.187-196, 1991. ,
URL : https://hal.archives-ouvertes.fr/inria-00510145
Precomputed radiance transfer for real-time rendering in dynamic, low-frequency lighting environments, Proc. SIGGRAPH 2002, pp.527-536, 2002. ,
Clustered Principal Components for Precomputed Radiance Transfer, ACM Trans. Graph, vol.22, issue.3, pp.382-391, 2003. ,
Local, deformable precomputed radiance transfer, ACM Trans. Graph, vol.24, issue.3, pp.1216-1224, 2005. ,
Bilateral filtering for gray and color images, Proc. ICCV 98, pp.839-846, 1998. ,
All-frequency precomputed radiance transfer using spherical radial basis functions and clustered tensor approximation, ACM Trans. Graph, vol.25, issue.3, pp.967-976, 2006. ,
Lightcuts: a scalable approach to illumination, ACM Trans. Graph, vol.24, issue.3, pp.1098-1107, 2005. ,
Multidimensional lightcuts, ACM Trans. Graph, vol.25, issue.3, pp.1081-1088, 2006. ,
A ray tracing solution for diffuse interreflection, Computer Graphics (Proc. SIGGRAPH 88), pp.85-92, 1988. ,
Face cluster radiosity, Proc. 10th Eurographics Workshop on Rendering 99, 1999. ,
Meshless methods based on collocation with radial basis functions, Computational Mechanics, vol.26, issue.4, pp.333-343, 2000. ,
