SACADEAU: A Decision-Aid System to improve Stream-Water Quality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ERCIM News Année : 2005
The objective of the SACADEAU project is to build a decision-aid tool to help specialists in charge of catchment area management to preserve stream-water quality. This is done by coupling a qualitative transfer model (simulating pesticide transfer through the catchment area) with a qualitative management model (simulating farmers~ decisions concerning weeding strategies and herbicide application). This has two main advantages: it allows the impact of recommendations to be evaluated by simulating high-level scenarios, and it allows simulation results to be analysed by using machine learning and data mining techniques to discover discriminating variables and to acquire knowledge in this poorly understood domain. The experimentation site (the Fremeur catchment area) is located in Brittany, France and covers about seventeen square kilometres.
Fichier non déposé
inria-00511099 , version 1 (23-08-2010)
  • HAL Id : inria-00511099 , version 1
Marie-Odile Cordier. SACADEAU: A Decision-Aid System to improve Stream-Water Quality. ERCIM News, 2005, 61, pp.37--38. ⟨inria-00511099⟩
122 Consultations
0 Téléchargements
