A machine learning approach for evaluating the impact of land use and management practices on streamwater pollution by pesticides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Streamwater pollution by pesticides is a critical environmental issue in farmed catchment areas. Many important factors are involved in this pollution phenomenon, like weather, area topology, land use and crop management practices, which all influence streamwater quality. The purpose of the ongoing study presented in this paper is to evaluate the impact of land use and management practices on streamwater pollution. We use modelling, simulation and machine learning techniques for acquiring knowledge about this complex domain. Our main objective is to learn qualitative rules relating the pollution factors to the temporal distribution of the stream pesticide concentration. The study area is the farmed catchment of Fremeur (~17 km2), located in Brittany, France. Our approach relies on a simulation model, called SACADEAU, based on two main components: a transfer model and a management model. The biophysical transfer model is the core of the model. It aims at simulating on a daily basis the pesticide transfer through the catchment area from application locations on maize parcels to the river. The management model simulates farmers\\\' operations like tillage, sowing, weeding (pesticide treatments described by dates, molecules, quantities) on maize crop parcels. A climate model, which provides daily weather data such as temperature and rainfall amount and a spatial model, which distributes in space the agricultural activities according to the fields and catchment area topology, are the two other components of the SACADEAU model. Using the outputs of these three sub-models, a biophysical transfer model determines herbicide outflow, modelling transfer from application locations, through the catchment area, to the stream. This simulation model is used for generating a large number of trajectories of the catchment system, considering different weather series or spatial distributions of land use and agricultural activities. The complexity of the model inputs and outputs makes difficult interpretation of results. Qualitative trajectories, or scenarios, are thus obtained by using machine learning techniques on these simulation data. ICL, an inductive logic programming software, is used for learning a set of rules which summarizes the scenarios. The Sacadeau model is not already fully implemented and first results have been obtained with a simplified model. We were able to check the coherence and the feasibility of our approach, and to build a first view of the role of some attributes in stream-water quality. Thanks to the complete model, more specific rules declined in terms of temporal and spatial variations should be established in the future.
Fichier non déposé
inria-00511101 , version 1 (23-08-2010)
  • HAL Id : inria-00511101 , version 1
  • PRODINRA : 247370
Marie-Odile Cordier, Frederick Garcia, Chantal Gascuel, Véronique Masson, Jordy Salmon-Monviola, et al.. A machine learning approach for evaluating the impact of land use and management practices on streamwater pollution by pesticides. MODSIM'05 (International Congress on Modelling and Simulation), Modelling and Simulation Society of Australia and New Zealand Inc. (MSSANZ). Canberra, AUS., 2005, Melbourne, Australia. ⟨inria-00511101⟩
323 Consultations
0 Téléchargements
