A formal framework for the decentralised diagnosis of large scale discrete event systems and its application to telecommunication networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Artificial Intelligence Année : 2005
We address the problem of diagnosing large discrete event systems. Given a flow of observations from the system, the goal is to explain these observations on-line by identifying and localising possible failures and their consequences across the system. Model-based diagnosis approaches deal with this problem but, apart very recent proposals, either they require the computation of a global model of the system which is not possible with large discrete event systems, or they cannot perform on-line diagnosis. The contribution of this paper is the description and the implementation of a formal framework for the on-line decentralised diagnosis of such systems, framework which is based on the ~divide and conquer~ principle and does not require the global model computation. This paper finally describes the use of this framework in the monitoring of a real telecommunication network.
Fichier non déposé
inria-00511104 , version 1 (23-08-2010)
  • HAL Id : inria-00511104 , version 1
Yannick Pencolé, Marie-Odile Cordier. A formal framework for the decentralised diagnosis of large scale discrete event systems and its application to telecommunication networks. Artificial Intelligence, 2005, 164 (1-2), pp.121-170. ⟨inria-00511104⟩
136 Consultations
0 Téléchargements
