Analysis of spread spectrum time domain reflectometry for wire fault location, IEEE Sensors Journal, vol.5, issue.6, pp.1469-1478, 2005. ,
DOI : 10.1109/JSEN.2005.858964
A simple and accurate model for wire diagnosis using reflectometry, PIERS Proceedings, 2007. ,
Distributed Reflectometry Method for Wire Fault Location Using Selective Average, IEEE Sensors Journal, vol.10, issue.2, pp.300-310, 2010. ,
DOI : 10.1109/JSEN.2009.2033946
The invisible fray: a critical analysis of the use of reflectometry for fray location, IEEE Sensors Journal, vol.6, issue.3, pp.697-706, 2006. ,
DOI : 10.1109/JSEN.2006.874017
Elements of Soliton Theory, 1980. ,
The inverse scattering transformation and the theory of solitons: an introduction, 1981. ,
Properties of dielectrics from reflection coefficients in one dimension, 1963. ,
Inversion of the telegraph equation and the synthesis of nonuniform lines, Proceedings of the IEEE, pp.383-392, 1971. ,
DOI : 10.1109/PROC.1971.8179
Inverse Scattering for Discrete Transmission-Line Models, SIAM Review, vol.29, issue.3, pp.359-389, 1987. ,
DOI : 10.1137/1029075
transmission lines, Journal of Mathematical Physics, vol.23, issue.12, pp.2286-2290, 1982. ,
DOI : 10.1063/1.525307
Recovering lossy multiconductor transmission line parameters from impedance or scattering representations, IEEE Transactions on Advanced Packaging, vol.25, issue.2, pp.200-205, 2002. ,
DOI : 10.1109/TADVP.2002.803273
Inverse Scattering for Soft Fault Diagnosis in Electric Transmission Lines, IEEE Transactions on Antennas and Propagation, vol.59, issue.1 ,
DOI : 10.1109/TAP.2010.2090462
URL : https://hal.archives-ouvertes.fr/inria-00365991
Inverse scattering problems in absorbing media, Journal of Mathematical Physics, vol.17, issue.7, pp.1351-1360, 1976. ,
DOI : 10.1063/1.523064
Analytical and numerical solution to the two-potential Zakharov-Shabat inverse scattering problem, IEEE Transactions on Antennas and Propagation, vol.40, issue.4, pp.399-404, 1992. ,
DOI : 10.1109/8.138841
Electromagnetic Waves and Antennas, 2008. ,
A numerical solution to the Zakharov-Shabat inverse scattering problem, IEEE Transactions on Antennas and Propagation, vol.39, issue.1, pp.74-79, 1991. ,
DOI : 10.1109/8.64438
Analytical and numerical solution to the two-potential Zakharov-Shabat inverse scattering problem, IEEE Transactions on Antennas and Propagation, vol.40, issue.4, pp.547-552, 1995. ,
An efficient algorithm for solving Zakharov-Shabat inverse scattering problem, IEEE Transactions on Antennas and Propagation, vol.50, issue.6, pp.807-811, 2002. ,
DOI : 10.1109/TAP.2002.1017660
An efficient numerical inverse scateering algorithm for the Zakharav-Shabat equations with two potential functions, 2009. ,
One-dimensional inverse scattering: exact methods and applications, 1986. ,
