Ordinal measures for image correspondence, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.4, pp.415-423, 1998. ,
DOI : 10.1109/34.677275
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.56.4638
« ´ Evaluation et comparaison de mesures de corrélation robustes aux occultations ». Rapport de recherche 2002-34-R, IRIT, 2002. ,
A new correlation criterion based on gradient fields similarity, Proceedings of 13th International Conference on Pattern Recognition, pp.632-636, 1996. ,
DOI : 10.1109/ICPR.1996.546101
« Le phénomène d'adhérence en stéréoscopie dépend du critère de corrélation, GRETSI, 2001. ,
« A Survey of Image Registration Techniques », ACM Computing Surveys, vol.24, issue.4, pp.325-376, 1992. ,
A stereo matching algorithm with an adaptive window: theory and experiment, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.9, pp.920-932, 1994. ,
DOI : 10.1109/34.310690
Robust image registration by increment sign correlation, Pattern Recognition, vol.35, issue.10, pp.2223-2234, 2002. ,
DOI : 10.1016/S0031-3203(01)00177-7
Using selective correlation coefficient for robust image registration, Pattern Recognition, vol.36, issue.5, pp.1165-1173, 2003. ,
DOI : 10.1016/S0031-3203(02)00081-X
« Méthodes robustes en vision : application aux appariements visuels, Thèse de doctorat, 1997. ,
Robust Matching by Partial Correlation., Procedings of the British Machine Vision Conference 1995, 1995. ,
DOI : 10.5244/C.9.65
URL : https://hal.archives-ouvertes.fr/inria-00548387
Robust location based partial correlation, 1997. ,
DOI : 10.1007/3-540-63460-6_132
URL : https://hal.archives-ouvertes.fr/inria-00073503
Robust regression and outlier detection, 1987. ,
DOI : 10.1002/0471725382
Robust estimation in very small samples, Computational Statistics & Data Analysis, vol.40, issue.4, pp.741-846, 2002. ,
DOI : 10.1016/S0167-9473(02)00078-6
« Schéma multirésolution d'estimation d'un champ de disparités dense sous contrainté epipolaire pour les images bruitées, GRETSI, 2001. ,
Taxomomy and Evaluation of Dense Two-Frame Stereo Correspondence Algorithms, International Journal of Computer Vision, vol.47, issue.1/3, pp.7-42, 2002. ,
DOI : 10.1023/A:1014573219977
« Orientation Code Matching For Robust Object Search, IEICE Transactions on Information and Systems, issue.8, pp.84-999, 2001. ,
Optimal, robust R-estimators and test statistics in the linear model, Statistics & Probability Letters, vol.14, issue.3, pp.179-188, 1992. ,
DOI : 10.1016/0167-7152(92)90019-2
Bounded-influence rank estimation in the linear model, Canadian Journal of Statistics, vol.18, issue.2, pp.233-245, 1994. ,
DOI : 10.2307/3315586
Non-parametric local transforms for computing visual correspondence, Proceedings of the European Conference on Computer Vision, pp.151-158, 1994. ,
DOI : 10.1007/BFb0028345
« Leprobì eme de la mise en correspondance : l'´ etat de l'art ». Rapport de recherche RR-2146, 1993. ,
Parameter estimation techniques: a tutorial with application to conic fitting, Image and Vision Computing, vol.15, issue.1, pp.59-76, 1997. ,
DOI : 10.1016/S0262-8856(96)01112-2
URL : https://hal.archives-ouvertes.fr/inria-00074015
« Traitement des occlusions pour la modification d'objet plan dans une séquence d'image, Actes du congrès francophone de Vision par Ordinateur ORASIS, pp.93-103, 1996. ,
