New interface
Preprints, Working Papers, ...
Traffic Capacity of Large WDM Passive Optical Networks
Abstract : As passive optical networks (PON) are increasingly deployed to provide high speed Internet access, it is important to understand their fundamental traffic capacity limits. The paper discusses performance models applicable to wavelength division multiplexing (WDM) EPONs and GPONs under the assumption that users access the fibre via optical network units equipped with tunable transmitters. The considered stochastic models are based on multiserver polling systems for which explicit analytical results are not known. A large system asymptotic, mean-field approximation, is used to derive closed form solutions of these complex systems. Convergence of the mean field dynamics is proved in the case of a simple network configuration. Simulation results show that, for a realistic sized PON, the mean field approximation is accurate.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00511868
Contributor : Philippe Robert Connect in order to contact the contributor
Submitted on : Thursday, August 26, 2010 - 2:45:05 PM
Last modification on : Friday, January 21, 2022 - 3:18:08 AM
Links full text
Identifiers
  • HAL Id : inria-00511868, version 1
  • ARXIV : 1002.2385
Collections
Citation
Nelson Antunes, Christine Fricker, Philippe Robert, James Roberts. Traffic Capacity of Large WDM Passive Optical Networks. 2010. ⟨inria-00511868⟩
Share
Metrics
Record views
87
