Learning from the Cell Life-cycle: a Self-Adaptive Paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Antinisca Di Marco
  • Fonction : Auteur
  • PersonId : 875208
Gallo Francesco
  • Fonction : Auteur
  • PersonId : 875209
Inverardi Paola
  • Fonction : Auteur
  • PersonId : 875210
In the software domain, self-adaptive systems are able to modify their behavior at run-time to respond to changes in the environment they run, to changes of the users' requirements or to changes occurring in the system it-self. In life science, biological cells are power entities able to adapt to the (unpredictable) situations they incur in, in a complete decentralized fashion. Learning adaptation mechanism from the cell life-cycle, we propose in this paper a new architectural paradigm for self-adaptive software systems.
ECSA2010.pdf (156.92 Ko) Télécharger le fichier
inria-00512415 , version 1 (18-11-2010)
  • HAL Id : inria-00512415 , version 1
Antinisca Di Marco, Gallo Francesco, Inverardi Paola, Rodolfo Ippoliti. Learning from the Cell Life-cycle: a Self-Adaptive Paradigm. Proc. of the 4th European Conference on Software Architecture (ECSA2010), 2010, Copenaghen, Denmark. ⟨inria-00512415⟩
Collections
CONNECT
53 Consultations
193 Téléchargements
