On the Logic of Theory Change : partial meet functions for contraction and revision, Journal of Symbolic Logic, vol.50, pp.510-530, 1985. ,
Conservative Adaptation in Metric Spaces, Proceedings of the 9th Conference on Case-Based Reasoning (ECCBR-08), pp.135-149, 2008. ,
Belief Merging-based Case Combination, Case- Based Reasoning Research and Development, pp.105-119, 2009. ,
An Algorithm for Adapting Cases Represented in an Expressive Description Logic, Proceedings of ICCBR-2010, 2010. ,
Le raisonnement par analogie en intelligence artificielle, pp.45-88, 1990. ,
Learning adaptation knowledge to improve case-based reasoning, Artificial Intelligence, vol.170, pp.16-17, 2006. ,
Case Base Mining for Adaptation Knowledge Acquisition, Proceedings of the 20th International Joint Conference on Artificial Intelligence (IJCAI'07), pp.750-755, 2007. ,
Adaptation Knowledge Acquisition : a Case Study for Case-Based Decision Support in Oncology, Computational Intelligence (an International Journal), vol.22, issue.34, pp.161-176, 2006. ,
Learning Adaptation Rules From a Case-Base Advances in Case-Based Reasoning ? Third European Workshop, pp.179-192, 1996. ,
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
Reformulation in Case-Based Reasoning, Fourth European Workshop on Case-Based Reasoning, EWCBR-98, pp.172-183, 1488. ,
Inside Case-Based Reasoning, 1989. ,
