Use case description of requirements for product lines, Proceedings of the International Workshop on Requirements Engineering for Product Lines, pp.12-19, 2002. ,
Use case-based testing of product lines, Proceedings of the 9th European Software Engineering Conference held jointly with 10th ACM SIGSOFT International Symposium on Foundations of Software Engineering, pp.355-358, 2003. ,
Testing Object-Oriented Systems, 2000. ,
A UML-based approach to system testing, J. Softw. Syst. Model, pp.10-42, 2002. ,
Modelling dependencies between variation points in use case diagrams, Proceedings of the 9th International Workshop on Requirements Engineering: Foundation For Software Quality ? REFSQ'03, 2003. ,
Software Product Lines: Practices and Patterns, 2001. ,
Structuring use cases with goals. J. Object-Oriented Program, pp.35-40, 1997. ,
Objects, Component, and Frameworks with UML: The Catalysis Approach, Chapter Interaction Models: Uses Cases, Actions, and Collaborations, 1999. ,
Automated Test Case Generation from Dynamic Models, Proceedings of the 14th European Conference on Object-Oriented Programming, 2000. ,
DOI : 10.1007/3-540-45102-1_23
Multiple-view meta-modeling of software product lines, Eighth IEEE International Conference on Engineering of Complex Computer Systems, 2002. Proceedings., pp.238-246, 2002. ,
DOI : 10.1109/ICECCS.2002.1181517
Communicating the variability of a software-product family to customers, Software and Systems Modeling, vol.2, issue.1, pp.15-36, 2003. ,
DOI : 10.1007/s10270-003-0019-9
TGV: theory, principles and algorithms, Proceedings of the 6th World Conference on Integrated Design and Process Technology, 2002. ,
DOI : 10.1007/s10009-004-0153-x
Product line modeling with generic use cases, Proceedings of SPLC2 Workshop on Techniques for Exploiting Commonality Through Variability Management, 2002. ,
Testing Variabilities in Use Case Models, Proceedings of the Fifth Workshop on Product Family Engineering, 2003. ,
DOI : 10.1007/978-3-540-24667-1_2
Filtering TOBIAS Combinatorial Test Suites, Proceedings of ETAPS/FASE'04 ? Fundamental Approaches to Software Engineering, 2004. ,
DOI : 10.1007/978-3-540-24721-0_21
Validation and automatic test generation on UML models: the AGATHA approach, International Journal on Software Tools for Technology Transfer, vol.1, issue.1/2, 2002. ,
DOI : 10.1007/s100090050009
Automated functional test case synthesis from THALES industrial requirements, Proceedings. RTAS 2004. 10th IEEE Real-Time and Embedded Technology and Applications Symposium, 2004., 2004. ,
DOI : 10.1109/RTTAS.2004.1317254
which significantly improved the data. Currently, our approach needs to be manually fed with the test data for the test generation and the simulation. Since the existing research work in the field principally aims at generating relevant test data for product line testing, future research can couple our approach with the existing work concerning test data generation and experiment the efficiency of the generated tests. Finally, our approach needs to be validated with real-world case studies ,
Automated requirements-based generation of test cases for product families, 18th IEEE International Conference on Automated Software Engineering, 2003. Proceedings., 2003. ,
DOI : 10.1109/ASE.2003.1240317
URL : https://hal.archives-ouvertes.fr/hal-00794804
System Test Synthesis from UML Models of Distributed Software, Proceedings of the 22nd Conference on Formal Techniques for Networked and Distributed Systems (FORTE'02), 2002. ,
DOI : 10.1007/3-540-36135-9_7
URL : https://hal.archives-ouvertes.fr/hal-00794606
Model-Based System Testing of Software Product Families, Proceedings of the 17th Conference on Advanced Information Systems Engineering (CaiSE'05), 2005. ,
DOI : 10.1007/11431855_36
Scent ? a method employing scenarios to systematically derive test cases for system test, 2000. ,
Product family testing, ACM SIGSOFT Software Engineering Notes, vol.29, issue.2, 2004. ,
DOI : 10.1145/979743.979766
Scenario usage in system development: a report on current practice, Proceedings of IEEE International Symposium on Requirements Engineering: RE '98, 1998. ,
DOI : 10.1109/ICRE.1998.667829
Behaviors generation from product lines requirements, Proceedings UML2004 Workshop on Software Architecture Description, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00795037
Testing a Software Product Line, 2001. ,
DOI : 10.1007/978-3-642-14335-9_4
Building Reusable Test Assets for a Product Line, Proceedings of the 7th International Conference on Software Reuse: Methods, Techniques, and Tools, pp.345-346, 2002. ,
DOI : 10.1007/3-540-46020-9_35
A Practical Guide to Testing Object-Oriented Software, 2001. ,
Applying 'design by contract', Computer, vol.25, issue.10, pp.40-51, 1992. ,
DOI : 10.1109/2.161279
Towards testing product line architectures Test and Analysis of Component Based Systems, Proceedings of the ETAPS03 Workshop, 2003. ,
A Requirement-Based Approach to Test Product Families, Proceedings of the 5th Workshop on Product Families Engineering (PFE-05, 2003. ,
DOI : 10.1007/978-3-540-24667-1_15
URL : https://hal.archives-ouvertes.fr/hal-00794799
Requirements by contracts allow automated system testing, 14th International Symposium on Software Reliability Engineering, 2003. ISSRE 2003., 2003. ,
DOI : 10.1109/ISSRE.2003.1251033
URL : https://hal.archives-ouvertes.fr/hal-00794812
Reusable test requirements for UML-modeled product lines, Proceedings of the Workshop REPL'02 (Requirements Engineering for Product Lines), 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00794640
