Using Model-Driven Engineering to generate QoS Monitors from a formal specification
In the domain of soft real-time application design, the gap between component-specification models and the im- plementations often implies that the implementations can- not fully take advantage of the specification models. To limit this gap, this paper proposes an approach to generate a QoS monitor from the timed behavior specification. To support this approach, we rely on two different component models: one focused on formal description and the other on prac- tical implementation. Those models are interconnected by model transformation, using a Model-Driven Engineering style.
Génie logiciel [cs.SE]
