Simultaneous analysis of Lasso and Dantzig selector, The Annals of Statistics, vol.37, issue.4, pp.1705-1732, 2009. ,
DOI : 10.1214/08-AOS620
URL : https://hal.archives-ouvertes.fr/hal-00401585
Least angle regression, Ann. Stat, vol.32, issue.2, pp.407-499, 2004. ,
Gradient methods for minimizing composite objective function, Center for Operations Research and Econometrics (CORE), 2007. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Structured variable selection with sparsity-inducing norms, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00377732
Group lasso with overlap and graph lasso, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553431
The composite absolute penalties family for grouped and hierarchical variable selection, The Annals of Statistics, vol.37, issue.6A, pp.3468-3497, 2009. ,
DOI : 10.1214/07-AOS584
Learning with structured sparsity, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553429
Model-Based Compressive Sensing, Theory, 2010. ,
DOI : 10.1109/TIT.2010.2040894
Tree-guided group lasso for multi-task regression with structured sparsity, Proc. ICML, 2010. ,
DOI : 10.1214/12-aoas549
URL : http://arxiv.org/abs/0909.1373
Proximal methods for sparse hierarchical dictionary learning, Proc. ICML, 2010. ,
The Group-Lasso for generalized linear models, Proceedings of the 25th international conference on Machine learning, ICML '08, 2008. ,
DOI : 10.1145/1390156.1390263
Regression shrinkage and selection via the Lasso, J. Roy. Stat. Soc. B, vol.58, issue.1, pp.267-288, 1996. ,
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
The benefit of group sparsity, The Annals of Statistics, vol.38, issue.4, 2009. ,
DOI : 10.1214/09-AOS778
Joint covariate selection and joint subspace selection for multiple classification problems, Statistics and Computing, vol.8, issue.68, pp.231-252, 2010. ,
DOI : 10.1007/s11222-008-9111-x
Exploring large feature spaces with hierarchical multiple kernel learning, Adv. NIPS, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00319660
Proximal Splitting Methods in Signal Processing, Fixed- Point Algorithms for Inverse Problems in Science and Engineering, 2010. ,
DOI : 10.1007/978-1-4419-9569-8_10
URL : https://hal.archives-ouvertes.fr/hal-00643807
About strongly polynomial time algorithms for quadratic optimization over submodular constraints, Mathematical Programming, vol.34, issue.3, pp.269-309, 1995. ,
DOI : 10.1007/BF01585561
Efficient projections onto the ? 1 -ball for learning in high dimensions, Proc. ICML, 2008. ,
An O(n) algorithm for quadratic knapsack problems, Operations Research Letters, vol.3, issue.3, pp.163-166, 1984. ,
DOI : 10.1016/0167-6377(84)90010-5
A Fast Parametric Maximum Flow Algorithm and Applications, SIAM Journal on Computing, vol.18, issue.1, pp.30-55, 1989. ,
DOI : 10.1137/0218003
Experimental Evaluation of Parametric Max-Flow Algorithms, 2006. ,
DOI : 10.1007/978-3-540-72845-0_20
A new approach to the maximum flow problem, Proc. of ACM Symposium on Theory of Computing, pp.136-146, 1986. ,
Maximal flow through a network, Journal canadien de math??matiques, vol.8, issue.0, pp.399-404, 1956. ,
DOI : 10.4153/CJM-1956-045-5
Linear Network Optimization, 1991. ,
On Implementing the Push???Relabel Method for the Maximum Flow Problem, Algorithmica, vol.19, issue.4, pp.390-410, 1997. ,
DOI : 10.1007/PL00009180
A unified framework for highdimensional analysis of M-estimators with decomposable regularizers, Adv. NIPS, 2009. ,
Convex analysis and nonlinear optimization: Theory and examples, 2006. ,
Robust Face Recognition via Sparse Representation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.2, pp.210-227, 2009. ,
DOI : 10.1109/TPAMI.2008.79
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.152.4658
Collaborative hierarchical sparse modeling, 2010 44th Annual Conference on Information Sciences and Systems (CISS), 2010. ,
DOI : 10.1109/CISS.2010.5464845
Convex Optimization, 2004. ,
