An alternative approach to linearly constrained adaptive beamforming, IEEE Transactions on Antennas and Propagation, pp.27-34, 1982. ,
DOI : 10.1109/TAP.1982.1142739
Sound capture from spatial volumes: Matched-filter processing of microphone arrays having randomlydistributed sensors, IEEE International Conference on Acoustics, Speech and Signal Processing, pp.917-920, 1996. ,
Signal enhancement using beamforming and nonstationarity with applications to speech, IEEE Transactions on Signal Processing, vol.49, issue.8, pp.1614-1626, 2001. ,
DOI : 10.1109/78.934132
Performance analysis of dual source transfer-function generalized sidelobe canceller, Speech Communication, vol.49, issue.7-8, pp.602-622, 2007. ,
DOI : 10.1016/j.specom.2006.12.007
Derivative constraints for broad-band element space antenna array processors, IEEE Transactions on Acoustics, Speech and Signal Processing, vol.31, issue.6, pp.1378-1393, 1983. ,
An adaptive generalized sidelobe canceller with derivative constraints, IEEE Transactions on Antennas and Propagation, vol.34, issue.3, pp.311-319, 1986. ,
DOI : 10.1109/TAP.1986.1143832
Spatial blocking filter derivative constraints for the generalized sidelobe canceller and MUSIC, IEEE Transactions on Signal Processing, vol.44, issue.1, pp.51-61, 1996. ,
DOI : 10.1109/78.482011
Generalized sidelobe cancellers with leakage constraints, IEEE International Symposium on Circuits and System, pp.3741-3744, 2005. ,
A source subspace tracking array of microphones for double talk situations, 1996 IEEE International Conference on Acoustics, Speech, and Signal Processing Conference Proceedings, pp.909-912, 1996. ,
DOI : 10.1109/ICASSP.1996.543269
A calibrated generalized sidelobe canceller for wideband beamforming, IEEE Transactions on Signal Processing, vol.42, issue.10, pp.2871-2875, 1994. ,
DOI : 10.1109/78.324759
An efficient low-complexity algorithm for crosstalk-resistant adaptive noise canceller, European Signal Processing Conference, pp.204-208, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00450770
Speech enhancement and recognition using circular microphone array for service robots, International Conference on Intelligent Robots and Systems, pp.3516-3521, 2003. ,
A robust adaptive beamformer for microphone arrays with a blocking matrix using constrained adaptive filters, IEEE Transactions on Signal Processing, pp.2677-2684, 1999. ,
Efficient frequency-domain realization of robust generalized, sidelobe cancellers, 2001 IEEE Fourth Workshop on Multimedia Signal Processing (Cat. No.01TH8564), pp.377-382, 2001. ,
DOI : 10.1109/MMSP.2001.962763
Some experimental and theoretical results using a new adaptive filter structure for noise cancellation in the presence of crosstalk, ICASSP '85. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.1253-1256, 1985. ,
DOI : 10.1109/ICASSP.1985.1168121
A new adaptive noise cancellation scheme in the presence of crosstalk, IEEE Transactions on circuits and systems II: Analog and Digital Signal Processing, pp.681-694, 1992. ,
Frequency-domain and multirate adaptive filtering, IEEE Signal Processing Magazine, vol.9, issue.1, pp.14-37, 1992. ,
DOI : 10.1109/79.109205
A two-step noise reduction technique, 2004 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.289-292, 2004. ,
DOI : 10.1109/ICASSP.2004.1325979
Analysis of noise reduction and dereverberation techniques based on microphone arrays with postfiltering, IEEE Transactions on Speech and Audio Processing, vol.6, issue.3, pp.240-259, 1998. ,
DOI : 10.1109/89.668818
Fast implementations of LMS adaptive filters, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.28, issue.4, pp.474-475, 1980. ,
DOI : 10.1109/TASSP.1980.1163432
