Elliptic curves in cryptography, 1999. ,
DOI : 10.1017/CBO9781107360211
An extension of Satoh's algorithm and its implementation, J. Ramanujan Math. Soc, vol.15, pp.281-318, 2000. ,
Finding Secure Curves with the Satoh-FGH Algorithm and an Early-Abort Strategy, Advances in Cryptology ? EUROCRYPT 2001, pp.14-29, 2001. ,
DOI : 10.1007/3-540-44987-6_2
URL : https://hal.archives-ouvertes.fr/inria-00514426
The GNU Multiple Precision arithmetic library ? 4.0.1. Swox AB, 2002. ,
Counting points with the arithmetic-geometric mean (joint work with J.-F. Mestre and P. Gaudry), 2001. ,
High-precision division and square root, ACM Transactions on Mathematical Software, vol.23, issue.4, 1994. ,
DOI : 10.1145/279232.279237
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.1679
Fast Elliptic Curve Point Counting Using Gaussian Normal Basis, Lecture Notes in Comput. Sci, vol.2369, pp.292-307, 2002. ,
DOI : 10.1007/3-540-45455-1_24
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.8915
The canonical lift of an ordinary elliptic curve over a finite field and its point counting, J. Ramanujan Math. Soc, vol.15, pp.247-270, 2000. ,
On p-adic Point Counting Algorithms for Elliptic Curves over Finite Fields, Lecture Notes in Comput. Sci, vol.2369, pp.43-66, 2002. ,
DOI : 10.1007/3-540-45455-1_5
Fast computation of canonical lifts of elliptic curves and its application to point counting, Finite Fields and Their Applications, vol.9, issue.1, 2001. ,
DOI : 10.1016/S1071-5797(02)00013-8
Elliptic curves over finite fields and the computation of square roots mod p, Math. Comp, vol.44, pp.483-494, 1985. ,
Satoh's algorithm in characteristic 2, Mathematics of Computation, vol.72, issue.241 ,
DOI : 10.1090/S0025-5718-02-01434-5
A Memory Efficient Version of Satoh???s Algorithm, Advances in Cryptology ? EURO- CRYPT 2001, pp.1-13, 2001. ,
DOI : 10.1007/3-540-44987-6_1
Modern computer algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
