R. L. Graham, Bounds on Multiprocessing Timing Anomalies, SIAM Journal on Applied Mathematics, vol.17, issue.2, pp.416-429, 1969.
DOI : 10.1137/0117039
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.90.8131
M. P. Mills, The internet begins with coal, Environment and Climate News, 1999.
T. Ishihara and H. Yasuura, Voltage scheduling problem for dynamically variable voltage processors, Proceedings of the 1998 international symposium on Low power electronics and design , ISLPED '98, pp.197-202, 1998.
DOI : 10.1145/280756.280894
P. Langen and B. Juurlink, Leakage-Aware Multiprocessor Scheduling, Journal of Signal Processing Systems, vol.74, issue.8, pp.73-88, 2009.
DOI : 10.1007/s11265-008-0176-8
R. Mishra, N. Rastogi, D. Zhu, D. Mossé, and R. Melhem, Energy aware scheduling for distributed realtime systems, Proc. of IPDPS, the Int. Parallel and Distributed Processing Symp, pp.21-29, 2003.
K. Pruhs, R. Van-stee, and P. Uthaisombut, Speed scaling of tasks with precedence constraints, Theory of Computing Systems, pp.67-80, 2008.
A. P. Chandrakasan and A. Sinha, JouleTrack: A Web Based Tool for Software Energy Profiling, Design Automation Conference, pp.220-225, 2001.
H. Aydin and Q. Yang, Energy-aware partitioning for multiprocessor real-time systems, Proceedings International Parallel and Distributed Processing Symposium, pp.113-121, 2003.
DOI : 10.1109/IPDPS.2003.1213225
J. Chen and T. Kuo, Multiprocessor energyefficient scheduling for real-time tasks, Proc. of International Conference on Parallel Processing (ICPP)
A. K. Chandra and C. K. Wong, Worst-Case Analysis of a Placement Algorithm Related to Storage Allocation, SIAM Journal on Computing, vol.4, issue.3, pp.249-263, 1975.
DOI : 10.1137/0204021
J. Y. Leung and W. Wei, Tighter bounds on a heuristic for a partition problem, Information Processing Letters, vol.56, issue.1, 1995.
DOI : 10.1016/0020-0190(95)00099-X
B. Awerbuch, Y. Azar, E. Grove, M. Kao, P. Krishnan et al., Load balancing in the lp norm, Proc. 36th Annual Symposium on Foundations of Computer Science (FOCS, pp.383-391, 1995.
N. Alon, Y. Azar, G. J. Woeginger, and T. Yadid, Approximation schemes for scheduling, Proc. 8th ACM- SIAM Symposium on Discrete Algorithms (SODA'97, 1997.
A. Avidor, Y. Azar, and J. Sgall, Ancient and new algorithms for load balancing in the lp norm, Proc. 9th ACM-SIAM Symposium on Discrete Algorithms (SODA'98). Society for Industrial and Applied Mathematics, pp.426-435, 1998.
J. Chen and T. Kuo, Procrastination determination for periodic real-time tasks in leakage-aware dynamic voltage scaling systems, Proc. of ICCAD'07, the Int. Conf. on Computer-aided design, pp.289-294, 2007.
J. Chen, Expected energy consumption minimization in DVS systems with discrete frequencies, Proceedings of the 2008 ACM symposium on Applied computing , SAC '08, pp.1720-1725, 2008.
DOI : 10.1145/1363686.1364095
L. Niu, Energy Efficient Scheduling for Real-Time Embedded Systems with QoS Guarantee, Proc. of RTCSA, the 16th Int. Conf. on Embedded and Real-Time Computing Systems and App, pp.163-172, 2010.
