A study on polynomials in separated variables with low genus factors, 2001. ,
Complex abelian varieties (2e) Grundlehren der mathematischen Wissenschaften, 2004. ,
The Magma Algebra System I: The User Language, Journal of Symbolic Computation, vol.24, issue.3-4, pp.3-4, 1997. ,
DOI : 10.1006/jsco.1996.0125
Moyenne arithmético-géometrique et périodes des courbes de genre 1 et 2, Gaz. Math, vol.38, pp.36-64, 1988. ,
The rank of J 0 (N ) Astérisque, pp.41-68, 1995. ,
Polytopal Linear Groups, Journal of Algebra, vol.218, issue.2, pp.715-737, 1999. ,
DOI : 10.1006/jabr.1998.7831
URL : http://doi.org/10.1006/jabr.1998.7831
Factorization of polynomials in several variables, Proceedings of the 15th Scandinavian Congress, pp.1-17, 1968. ,
DOI : 10.1093/qmath/12.1.304
Factorisations explicities de g(y) ? h(z) Acta Arith, pp.291-317, 1999. ,
On nondegeneracy of curves. Algebra Number Theory 3 no, pp.255-281, 2009. ,
A note on the existence of absolutely simple Jacobians, Journal of Pure and Applied Algebra, vol.155, issue.2-3, pp.115-120, 2001. ,
DOI : 10.1016/S0022-4049(99)00096-1
), The Quarterly Journal of Mathematics, vol.12, issue.1, pp.304-312, 1961. ,
Two problems concerning polynomials, J. Reine Angew. Math, vol.214, pp.386-391, 1964. ,
The arithmetic-geometric mean and isogenies for curves of higher genus, Ann. Scuola Norm. Sup. Pisa Cl. Sci, vol.28, issue.4 2, pp.323-339, 1999. ,
Automorphisms of symmetric balanced incomplete block designs, Mathematische Zeitschrift, vol.21, issue.1, pp.40-49, 1970. ,
DOI : 10.1007/BF01109892
On symmetric balanced incomplete block designs with doubly transitive automorphism groups, Journal of Combinatorial Theory, Series A, vol.14, issue.2, pp.221-247, 1973. ,
DOI : 10.1016/0097-3165(73)90024-1
Some consequences of the classification of finite simple groups, Proc. Symposia Pure Math, pp.175-181, 1980. ,
DOI : 10.1090/pspum/037/604576
On a conjecture of Schur. Michigan Math, J, vol.17, pp.41-55, 1970. ,
The field of definition of function fields and a problem in the reducibility of polynomials in two variables, Illinois J. Math, pp.17-128, 1973. ,
Exposition on an arithmetic-group theoretic connection via Riemann???s existence theorem, Proceedings of Symposia in Pure Math, pp.571-602, 1980. ,
DOI : 10.1090/pspum/037/604636
Intersection theory (2e), 1998. ,
An Extension of Kedlaya???s Point-Counting Algorithm to Superelliptic Curves, Advances in cryptology: ASIACRYPT 2001, pp.480-494, 2001. ,
DOI : 10.1007/3-540-45682-1_28
The classification of the finite simple groups, AMS Mathematical surveys and monographs, vol.401, 1994. ,
Some notes on Kedlaya's algorithm for hyperelliptic curves. arXiv math.NT / 1006, p.1, 2010. ,
On Brumer's family of {RM}-curves of genus two, Tohoku Mathematical Journal, vol.52, issue.4, pp.475-488, 2000. ,
DOI : 10.2748/tmj/1178207751
On the Existence of Absolutely Simple Abelian Varieties of a Given Dimension over an Arbitrary Field, Journal of Number Theory, vol.92, issue.1, pp.139-163, 2002. ,
DOI : 10.1006/jnth.2001.2697
Counting points on hyperelliptic curves using Monsky?Washnitzer cohomology, J. Ramanujan Math. Soc, vol.16, issue.4, pp.323-338, 2001. ,
The number of moduli of families of curves on toric surfaces, 1991. ,
Construction of algebraic correspondences between hyperelliptic function fields using Deuring's theory, 2004. ,
Pitman monographs and surveys in pure and applied mathematics 65, Longman Scientific and Technical, 1993. ,
Couples de jacobiennes isogénes de courbes hyperelliptiques de genre arbitraire. arXiv math.AG / 0902, p.1, 2009. ,
Familles de courbes hyperelliptiquesàhyperelliptiquesà multiplications réelles, Arithmetic algebraic geometry (Texel Progr. Math, 1989. ,
Principally polarized abelian varieties of dimension two or three are Jacobian varieties, J. Fac. Sci. Univ. Tokyo, Sect IA: Math, vol.20, pp.377-381, 1973. ,
Graded rings and varieties in weighted projective space. Manuscript available from www.maths.warwick.ac.uk ,
Abelian varieties with complex multiplication and modular functions. Princeton mathematical series 46, 1998. ,
Families of explicit isogenies of hyperelliptic Jacobians Arithmetic, Geometry, Cryptography and Coding Theory, Contemp. Math, pp.521-121, 2009. ,
Isogenies and the discrete logarithm problem in Jacobians of genus 3 hyperelliptic curves, EUROCRYPT 2008, pp.163-180, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00537860
Explicit hyperelliptic curves with real multiplication and permutation polynomials, Journal canadien de math??matiques, vol.43, issue.5, pp.1055-1064, 1991. ,
DOI : 10.4153/CJM-1991-061-x
Isogénies entre courbes elliptiques, C. R. Acad. Sci. Paris, vol.273, pp.238-241, 1971. ,
Endomorphisms of superelliptic Jacobians. arXiv math, p.4, 2008. ,
The endomorphism rings of jacobians of cyclic covers of the projective line, Math. Proc. Cambridge Philos. Soc. 136 no, pp.257-267, 2004. ,
DOI : 10.1017/S0305004103007102
Hyperelliptic Jacobians without Complex Multiplication, doubly transitive permutation groups and projective representations Algebraic number theory and algebraic geometry, Contemp. Math, pp.300-195, 2002. ,
DOI : 10.1090/conm/300/05149
URL : http://arxiv.org/abs/math/0201185
Superelliptic Jacobians. arXiv math, p.4, 2006. ,
DOI : 10.1007/s00209-005-0921-7
URL : http://arxiv.org/abs/math/0303001
