Articulated body deformation from range scan data, ACM Transactions on Graphics, vol.21, issue.3, pp.612-619, 2002. ,
A log-Euclidean polyaffine framework for locally rigid or affine registration, proc. of WBIR, pp.120-127, 2006. ,
An algorithmic overview of surface registration techniques for medical imaging, Medical Image Analysis, vol.4, issue.3, pp.201-217, 2000. ,
Construction and animation of anatomically based human hand models, Proc. of Symp. on Computer Animation '03, pp.368-98, 2003. ,
Scape: Shape completion and animation of people, Proc. of SIGGRAPH, 2005. ,
Fast contact force computation for nonpenetrating rigid bodies, Proc. of SIGGRAPH, pp.23-34, 1994. ,
Linear-time dynamics using lagrange multipliers, Proc. of SIGGRAPH, pp.137-146, 1996. ,
Topology-Invariant Similarity of Nonrigid Shapes, International Journal of Computer Vision, vol.9, issue.2, pp.281-301, 2009. ,
DOI : 10.1007/s11263-008-0172-2
A method for registration of 3-d shapes, IEEE Trans. PAMI, vol.14, issue.2, pp.239-256, 1992. ,
Generalized gradients: Priors on minimization flows, Int. J. of Computer Vision, vol.73, issue.3, pp.325-344, 2007. ,
Automatic registration for articulated shapes, Proc. of SGP, Comp. Graph. Forum, 2008. ,
Range scan registration using reduced deformable models, Proc. of Eurographics, pp.447-456, 2009. ,
Performance capture from sparse multi-view video, Proc. of SIGGRAPH, p.3, 2008. ,
Fast iterative refinement of articulated solid dynamics, IEEE TVCG, vol.5, issue.3, pp.268-276, 1999. ,
Fast musculoskeletal registration based on shape matching, Proc. of MICCAI'08, pp.822-829, 2008. ,
Non-rigid registration under isometric deformations, Comput. Graph. Forum, vol.27, issue.5, pp.1449-1457, 2008. ,
Closedform solution of absolute orientation using orthonormal matrices, J. of the Optical Society of America, vol.5, pp.1127-1135, 1988. ,
Hierarchical implicit surface joint limits for human body tracking, Computer Vision and Image Understanding, vol.99, issue.2, pp.189-209, 2005. ,
Modeling deformable human hands from medical images, Proc. of Symposium on Computer Animation'04, pp.355-363, 2004. ,
Robust single-view geometry and motion reconstruction, Proc. of SIGGRAPH Asia, 2009. ,
A procedural approach to solving constraints of articulated bodies, Proc. of Eurographics, 2000. ,
Global correspondence optimization for non-rigid registration of depth scans, Proc. of SGP, 2008. ,
Articulated shape matching using laplacian eigenfunctions and unsupervised point registration, Proc. of IEEE CVPR, pp.1-8, 2008. ,
Automatic joint parameter estimation from magnetic motion capture data, Proc. of Graphics Interface '00, pp.53-60, 2000. ,
Articulated Rigid Registration for Serial Lower-Limb Mouse Imaging, Proc. of MICCAI, vol.3750, pp.919-926, 2005. ,
DOI : 10.1007/11566489_113
Image registration by local histogram matching, Pattern Recognition, vol.40, issue.4, pp.1161-1172, 2007. ,
Musculotendon simulation for hand animation, Proc. of SIGGRAPH'08, pp.3-83, 2008. ,
Image deformation using moving least squares, Proc. of SIGGRAPH), pp.533-540, 2006. ,
Skeleton based shape matching and retrieval, Proc. IEEE Conf. on Shape Modeling and Applications, pp.130-142, 2003. ,
Embedded deformation for shape manipulation, Proc. of SIGGRAPH, 2007. ,
Segmentation of carpal bones from CT images using skeletally coupled deformable models, Medical Image Analysis, vol.7, issue.1, pp.21-45, 2003. ,
DOI : 10.1016/S1361-8415(02)00065-8
Creating and Simulating Skeletal Muscle from the Visible Human Data Set, IEEE Transactions on Visualization and Computer Graphics, vol.11, issue.3, pp.317-328, 2005. ,
DOI : 10.1109/TVCG.2005.42
Articulated mesh animation from multi-view silhouettes, ACM Transactions on Graphics, vol.27, issue.97, pp.1-97, 2008. ,
Incorporating rigid structures in non-rigid registration using triangular b-splines, pp.235-246, 2005. ,
Dynamic simulation of articulated rigid bodies with contact and collision, IEEE TVCG, vol.12, pp.365-374, 2006. ,
Joint-aware manipulation of deformable models, ACM Trans. Graph. (proc. of SIGGRAPH), vol.28, p.3, 2009. ,
Deformation-driven shape correspondence, Comp. Graph. Forum (Proc. of SGP), vol.27, issue.5, pp.1431-1439, 2008. ,
