A Procedural Approach to Animate Interactive Natural Sceneries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper presents a method for animating and rendering an interactive natural scenery in real-time. It improves the prairie model of [11] by enabling the on-the-fly generation of blades of grass, at three different levels of detail, from user-specified density maps. A new animation function, the tread on grass, is defined to allow virtual objects or characters to crush the grass. The resulting grass model is incorporated into a more complex natural scene with the adjunction of trees that respond to the same wind. Results are illustrated by the real-time animation of autonomous virtual humans interacting with this natural scenery.
paper.pdf (276.91 Ko) Télécharger le fichier
pierrePrairie.avi (87.02 Mo) Télécharger le fichier
prairie-recover_mp1.mpg (2.59 Mo) Télécharger le fichier
prairie_mp1.mpg (14 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
inria-00516890 , version 1 (13-09-2010)
  • HAL Id : inria-00516890 , version 1
Guerraz Sylvain, Frank Perbet, David Raulo, François Faure, Marie-Paule Cani. A Procedural Approach to Animate Interactive Natural Sceneries. 16th International Conference on Computer Animation and Social Agents, CASA 2003, May 2003, New Brunswick, NJ, United States. ⟨inria-00516890⟩
471 Consultations
2371 Téléchargements
