Abstract : We consider the dynamical behavior of Martin-Löf random points in dynamical systems over metric spaces with a computable dynamics and a computable invariant measure. We use computable partitions to define a sort of effective symbolic model for the dynamics. Through this construction we prove that such points have typical statistical behavior (the behavior which is typical in the Birkhoff ergodic theorem) and are recurrent. We introduce and compare some notions of complexity for orbits in dynamical systems and prove: (i) that the complexity of the orbits of random points equals the Kolmogorov-Sinaï entropy of the system, (ii) that the supremum of the complexity of orbits equals the topological entropy.
https://hal.inria.fr/inria-00517382 Contributor : Mathieu HoyrupConnect in order to contact the contributor Submitted on : Tuesday, September 14, 2010 - 2:33:19 PM Last modification on : Wednesday, May 4, 2022 - 3:14:21 AM Long-term archiving on: : Tuesday, October 23, 2012 - 4:11:12 PM
