Computational geometry: algorithms and applications, 1997. ,
A kinetic framework for computational geometry, 24th Annual Symposium on Foundations of Computer Science (sfcs 1983), pp.100-111, 1983. ,
DOI : 10.1109/SFCS.1983.1
Computational geometry in C. Cambridge, 1985. ,
Computational geometry: an introduction, 1985. ,
DOI : 10.1007/978-1-4612-1098-6
Computer graphics: principles and practice, 1990. ,
Vector and Raster Hidden-Surface Removal Using Parallel Connected Stripes, IEEE Computer Graphics and Applications, vol.7, issue.7, pp.14-23, 1987. ,
DOI : 10.1109/MCG.1987.277009
URL : http://puma.isti.cnr.it/rmydownload.php?filename=cnr.isti/cnr.iei/1985-B4-030/1985-B4-030_0.pdf
A visible polygon reconstruction algorithm, ACM SIGGRAPH Computer Graphics, vol.15, issue.3, pp.17-26, 1981. ,
DOI : 10.1145/965161.806785
Reentrant polygon clipping, Communications of the ACM, vol.17, issue.1, pp.32-42, 1974. ,
DOI : 10.1145/360767.360802
Hidden surface removal using polygon area sorting, Proceedings of the SIGGRAPH, pp.214-236, 1977. ,
DOI : 10.1145/563858.563896
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.137.7161
Polygon comparison using a graph representation, ACM SIGGRAPH Computer Graphics, vol.14, issue.3, pp.10-18, 1980. ,
DOI : 10.1145/965105.807462
Polyhedral modelling with multiprecision integer arithmetic, Computer-Aided Design, vol.29, issue.2, pp.123-156, 1997. ,
DOI : 10.1016/S0010-4485(96)00041-3
Determination of mass properties of polygonal CSG objects in parallel, Proceedings of the First Symposium on Solid Modeling Foundations and CAD/CAM Applications, pp.279-88, 1991. ,
An algorithm reducing 3D Boolean operations to a 2D problem: concepts and results, Computer-Aided Design, vol.28, issue.4, pp.277-87, 1996. ,
DOI : 10.1016/0010-4485(95)00050-X
Robust set operations on polyhedral solids, IEEE Computer Graphics and Applications, vol.9, issue.6, pp.50-59, 1989. ,
DOI : 10.1109/38.41469
NC machining of arbitrarily shaped pockets, Computer-Aided Design, vol.10, issue.3, pp.169-74, 1978. ,
DOI : 10.1016/0010-4485(78)90141-0
Algorithm for Clpping Arbitrary Polygons, Computer Graphics Forum, vol.4, issue.4, pp.183-91, 1989. ,
DOI : 10.1016/0097-8493(87)90061-6
Efficient clipping of arbitrary polygons, ACM Transactions on Graphics, vol.17, issue.2, pp.71-83, 1998. ,
DOI : 10.1145/274363.274364
An analysis and algorithm for polygon clipping, Communications of the ACM, vol.26, issue.11, pp.868-77, 1983. ,
DOI : 10.1145/182.358439
A new, fast method for 2D polygon clipping: analysis and software implementation, ACM Transactions on Graphics, vol.11, issue.3, pp.276-90, 1992. ,
DOI : 10.1145/130881.130894
An edge labeling approach to concave polygon clipping, Manuscript, pp.1-10, 1995. ,
A generic solution to polygon clipping, Communications of the ACM, vol.35, issue.7, pp.56-63, 1992. ,
DOI : 10.1145/129902.129906
Polygon Boolean operation based on edges recognition algorithm, Chinese], pp.260-265, 1994. ,
Computational geometry: algorithms analysis and design, 2000. ,
Geometric modelling based on simplicial chains, Computers & Graphics, vol.22, issue.5, pp.611-620, 1998. ,
DOI : 10.1016/S0097-8493(98)00067-3
Boolean operations on general planar polygons, Computers & Graphics, vol.24, issue.6, pp.881-96, 2000. ,
DOI : 10.1016/S0097-8493(00)00090-X
Orientation, simplicity, and inclusion test for planar polygons, Computers & Graphics, vol.19, issue.4, pp.595-600, 1995. ,
DOI : 10.1016/0097-8493(95)00037-D
Inclusion test for curved-edge polygons, Computers and Graphics, vol.21, issue.6, pp.815-839, 1997. ,
