Efficient algorithm for general polygon clipping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Yu Peng
  • Fonction : Auteur
Junhai Yong
  • Fonction : Auteur
Hui Zhang
  • Fonction : Auteur
Jiaguang Sun
  • Fonction : Auteur
We present an efficient algorithm to determine the intersection of two planar general polygons. A new method based on rotation angle is proposed to obtain the classification of an edge with respect to a polygon. The edge candidates can be determined efficiently by a 1-dimensional range searching approach based on an AVL tree (a balanced binary search tree). The simplicial chain is used to represent the general polygons, and to determine the classification of polygon edges. Examples are given to illustrate the algorithm.
YuPeng2005b.pdf (244.91 Ko) Télécharger le fichier
inria-00517687 , version 1 (15-09-2010)
  • HAL Id : inria-00517687 , version 1
  • PRODINRA : 247305
Yu Peng, Junhai Yong, Hui Zhang, Jiaguang Sun. Efficient algorithm for general polygon clipping. Proceedings of The 6th International Conference on Computer-Aided Industrial Design and Conceptual Design 2005, May 2005, Delft, Netherlands. ⟨inria-00517687⟩
240 Consultations
1649 Téléchargements
