A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
DOI : 10.1109/34.121791
A counterexample on point inversion and projection for NURBS curve, Computer Aided Geometric Design, vol.24, issue.5, p.302, 2007. ,
DOI : 10.1016/j.cagd.2007.03.008
URL : https://hal.archives-ouvertes.fr/inria-00201817
Distance calculation between a point and a NURBS surface, Curve and Surface Design, pp.55-62, 1999. ,
On the curvature of curves and surfaces defined by normalforms, Computer Aided Geometric Design, vol.16, issue.5, pp.355-376, 1999. ,
DOI : 10.1016/S0167-8396(99)00003-5
A second order algorithm for orthogonal projection onto curves and surfaces, Computer Aided Geometric Design, vol.22, issue.3, pp.251-260, 2005. ,
DOI : 10.1016/j.cagd.2004.12.001
A framework for efficient minimum distance computations, Proceedings. 1998 IEEE International Conference on Robotics and Automation (Cat. No.98CH36146), pp.3678-3684, 1998. ,
DOI : 10.1109/ROBOT.1998.681403
Geometric algorithms for the intersection of curves and surfaces, Computers & Graphics, vol.19, issue.3, pp.391-403, 1995. ,
DOI : 10.1016/0097-8493(95)00009-2
Point inversion and projection for NURBS curve and surface: Control polygon approach, Computer Aided Geometric Design, vol.20, issue.2, pp.79-99, 2003. ,
DOI : 10.1016/S0167-8396(03)00021-9
Geometric Modeling, pp.305-317, 1985. ,
Surface Curve Design by Orthogonal Projection of Space Curves Onto Free-Form Surfaces, Journal of Mechanical Design, vol.118, issue.1, pp.45-52, 1996. ,
DOI : 10.1115/1.2826855
Parametrization for surface fitting in reverse engineering, Computer-Aided Design, vol.33, issue.8, pp.593-603, 2001. ,
DOI : 10.1016/S0010-4485(00)00103-2
Registration without ICP, Computer Vision and Image Understanding, vol.95, issue.1, pp.54-71, 2004. ,
DOI : 10.1016/j.cviu.2004.04.002
Improved algorithms for the projection of points on NURBS curves and surfaces, Computer Aided Geometric Design, vol.23, issue.5, pp.439-445, 2006. ,
DOI : 10.1016/j.cagd.2006.01.007
Newton methods for parametric surface registration. Part II. Experimental validation, Computer-Aided Design, vol.35, issue.1, pp.115-120, 2003. ,
DOI : 10.1016/S0010-4485(01)00215-9
Computation of stationary points of distance functions, Engineering with Computers, vol.21, issue.8, pp.231-246, 1993. ,
DOI : 10.1007/BF01201903
