Disparity and normal estimation through alternating maximization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose an algorithm that recovers binocular disparities in accordance with the surface properties of the scene under consideration. To do so, we estimate the disparity as well as the normals in the disparity space, by setting the two tasks in a unified framework. A novel joint probabilistic model is defined through two random fields to favor both intra field (within neighboring disparities and neighboring normals) and inter field (between disparities and normals) consistency. Geometric contextual information is introduced in the models for both normals and disparities, which is optimized using an appropriate alternating maximization procedure. We illustrate the performance of our approach on synthetic and real data.
icip10_final3382.pdf (1001.69 Ko) Télécharger le fichier
ramya_icip10_poster.pdf (1.98 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00517864 , version 1 (15-09-2010)
Ramya Narasimha, Élise Arnaud, Florence Forbes, Radu Horaud. Disparity and normal estimation through alternating maximization. ICIP 2010 - 17 IEEE International Conference on Image Processing, Sep 2010, Honk Kong, China. pp.2969-2972, ⟨10.1109/ICIP.2010.5653453⟩. ⟨inria-00517864⟩
244 Consultations
397 Téléchargements
