The design and analysis of computer algorithms ,
A Uniform Approach for the Fast Computation of Matrix-Type Pad?? Approximants, SIAM Journal on Matrix Analysis and Applications, vol.15, issue.3, pp.3-804, 1994. ,
DOI : 10.1137/S0895479892230031
Asymptotically fast solution of toeplitz and related systems of linear equations, Linear Algebra and its Applications, vol.34, pp.103-116, 1980. ,
DOI : 10.1016/0024-3795(80)90161-5
Strategies in Filtering in the Number Field Sieve, ANTS-IV, pp.209-231, 2000. ,
DOI : 10.1007/10722028_11
Factorization of a 512-Bit RSA Modulus, Preneel [21], pp.1-18 ,
DOI : 10.1007/3-540-45539-6_1
URL : https://hal.archives-ouvertes.fr/inria-00099117
Fast evaluation of logarithms in fields of characteristic two, IEEE Transactions on Information Theory, vol.30, issue.4, pp.587-594, 1984. ,
DOI : 10.1109/TIT.1984.1056941
Solving linear equations over GF(2): block Lanczos algorithm, Linear Algebra and its Applications, vol.192, pp.33-60, 1993. ,
DOI : 10.1016/0024-3795(93)90235-G
URL : http://doi.org/10.1016/0024-3795(93)90235-g
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
DOI : 10.2307/2153413
Modern Computer Algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
An Algorithm for Solving the Discrete Log Problem on Hyperelliptic Curves, Preneel [21], pp.19-34 ,
DOI : 10.1007/3-540-45539-6_2
URL : https://hal.archives-ouvertes.fr/inria-00512401
Algorithmique des courbes hyperelliptiques et applicationsàapplications`applicationsà la cryptologie, Thèse, ´ Ecole Polytechnique, 2000. ,
URL : https://hal.archives-ouvertes.fr/tel-00514848
Fast algorithms for rational Hermite approximation and solution of Toeplitz systems, IEEE Transactions on Circuits and Systems, vol.26, issue.9, pp.750-755, 1979. ,
DOI : 10.1109/TCS.1979.1084696
Analysis of Coppersmith's block Wiedemann algorithm for the parallel solution of sparse linear systems, Math. Comp, vol.64, pp.210-777, 1995. ,
Distributed Matrix-Free Solution of Large Sparse Linear Systems over Finite Fields, Algorithmica, vol.24, issue.3-4, pp.331-348, 1999. ,
DOI : 10.1007/PL00008266
Solving Large Sparse Linear Systems Over Finite Fields, Advances in Cryptology ? CRYPTO '90, pp.109-133, 1990. ,
DOI : 10.1007/3-540-38424-3_8
A Block Lanczos Algorithm for Finding Dependencies over GF(2), Advances in Cryptology ? EUROCRYPT '95, pp.106-120, 1995. ,
DOI : 10.1007/3-540-49264-X_9
Doubling algorithms for Toeplitz and related equations, ICASSP '80. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.954-959, 1980. ,
DOI : 10.1109/ICASSP.1980.1171074
Discrete logarithms in finite fields and their cryptographic significance, Advances in Cryptology ? EUROCRYPT '84, pp.224-314, 1985. ,
DOI : 10.1007/3-540-39757-4_20
Reduction of Huge, Sparse Matrices over Finite Fields Via Created Catastrophes, Experimental Mathematics, vol.32, issue.2, pp.89-94, 1992. ,
DOI : 10.1080/10586458.1992.10504250
Advances in Cryptology ? EURO- CRYPT, Lecture Notes in Comput. Sci, vol.1807, 2000. ,
Euclid's algorithm and the Lanczos method over finite fields, Mathematics of Computation, vol.67, issue.224, pp.1665-1678, 1998. ,
DOI : 10.1090/S0025-5718-98-00973-9
Further analysis of Coppersmith's block Wiedemann algorithm for the solution of sparse linear systems (extended abstract), Proceedings of the 1997 international symposium on Symbolic and algebraic computation , ISSAC '97, pp.32-39, 1997. ,
DOI : 10.1145/258726.258742
A study of Coppersmith's block Wiedemann algorithm using matrix polynomials, Research report LMC-IMAG, vol.975, 1997. ,
The solution of McCurley's discrete log challenge, Advances in Cryptology ? CRYPTO '98, pp.458-471, 1998. ,
DOI : 10.1007/BFb0055747
Solving sparse linear equations over finite fields, IEEE Transactions on Information Theory, vol.32, issue.1, pp.54-62, 1986. ,
DOI : 10.1109/TIT.1986.1057137
