Automatic CNC milling of pockets: geometric and technological issues, Computer Integrated Manufacturing Systems, vol.11, issue.4, pp.309-330, 1998. ,
DOI : 10.1016/S0951-5240(98)00030-5
Multiresolution offsetting and loose convex hull clipping for 2.5D NC machining, Computer-Aided Design, vol.36, issue.7, pp.625-637, 2004. ,
DOI : 10.1016/S0010-4485(03)00139-8
Uneven offset method of NC tool path generation for free-form pocket machining, Computers in Industry, vol.43, pp.97-103, 2000. ,
Sahpe Interrogation for Computer Aided Design and Manufacturing, 2002. ,
A new approach to CNC tool path generation, Computer-Aided Design, vol.30, pp.649-655, 1998. ,
Contour offset approach to spiral toolpath generation with constant scallop height, Computer-Aided Design, vol.35, issue.6, pp.511-518, 2003. ,
DOI : 10.1016/S0010-4485(01)00185-3
A locus tracing algorithm for cutter offsetting in CNC machining, Robotics and Computer-Integrated Manufacturing, vol.20, issue.1, pp.49-55, 2004. ,
DOI : 10.1016/S0736-5845(03)00067-X
Swift and stable polygon growth and broken line offset, Computer-Aided Design, vol.30, issue.11, pp.847-852, 1998. ,
DOI : 10.1016/S0010-4485(98)00041-4
Rational curves and surfaces with rational offsets, Computer Aided Geometric Design, vol.12, issue.2, pp.175-192, 1995. ,
DOI : 10.1016/0167-8396(94)00008-G
Offset curves and surfaces: a brief survey, Computer-Aided Design, vol.24, issue.4, pp.223-239, 1992. ,
DOI : 10.1016/0010-4485(92)90059-J
An overview of offset curves and surfaces, Computer-Aided Design, vol.31, issue.3, pp.165-173, 1999. ,
DOI : 10.1016/S0010-4485(99)00013-5
One-sided arc approximation of B-spline curves for interference-free offsetting, Computer-Aided Design, vol.31, issue.2, pp.111-118, 1999. ,
DOI : 10.1016/S0010-4485(99)00019-6
Planar curve offset based on circle approxmation, Computer-Aided Design, vol.26, pp.517-530, 1995. ,
DOI : 10.1016/0010-4485(95)00078-x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.23.5225
IGB-offset for plane curves???loop removal by scanning of interval sequences, Computer Aided Geometric Design, vol.15, issue.4, pp.339-375, 1998. ,
DOI : 10.1016/S0167-8396(97)00038-1
The biarc approximation of planar NURBS curve and its offset, Journal of Software, vol.11, pp.1368-1374, 2000. ,
Offsetting operations via closed ball approximation, Computer-Aided Design, vol.27, issue.11, pp.805-810, 1995. ,
DOI : 10.1016/0010-4485(95)00031-3
Conic Approximation of Conic Offsets, Journal of Symbolic Computation, vol.23, issue.2-3, pp.301-313, 1997. ,
DOI : 10.1006/jsco.1996.0090
Computing offsets of NURBS curves and surfaces, Computer-Aided Design, vol.31, issue.2, pp.147-156, 1999. ,
DOI : 10.1016/S0010-4485(98)00066-9
Approximation of circular arcs and offset curves by B??zier curves of high degree, Journal of Computational and Applied Mathematics, vol.167, issue.2, pp.405-416, 2004. ,
DOI : 10.1016/j.cam.2003.10.008
A pair-wise offset algorithm for 2D point-sequence curve, Computer-Aided Design, vol.31, issue.12, pp.735-745, 1999. ,
DOI : 10.1016/S0010-4485(99)00060-3
Offset of planar curves based on polylines, Journal of Institute of Command and Technology, vol.12, pp.5-8, 2001. ,
CIM algorithm for approximating threedimensional polygonal curves, Journal of Computer Science and Technology, vol.6, pp.552-559, 2001. ,
Unbalanced Hermite Interpolation with Tschirnhausen Cubics, LNCS (Lecture Notes in Computer Science), vol.3314, pp.1072-1078, 2004. ,
DOI : 10.1007/978-3-540-30497-5_165
Optimising automatic tool selection for 2 1 ,
