Variable-radius blending of parametric surfaces, The Visual Computer, vol.7, issue.10, pp.513-538, 1995. ,
DOI : 10.1007/BF02434038
Variable-radius blending by constrained spine generation, The Visual Computer, vol.13, issue.7, pp.316-345, 1997. ,
DOI : 10.1007/s003710050106
Composing B??zier simplexes, ACM Transactions on Graphics, vol.7, issue.3, pp.198-221, 1988. ,
DOI : 10.1145/44479.44482
Functional composition algorithms via blossoming, ACM Transactions on Graphics, vol.12, issue.2, pp.113-148, 1993. ,
DOI : 10.1145/151280.151290
An Approximately G1 Cubic Surface Interpolant, Mathematical methods in computer aided geometric design, pp.185-96, 1992. ,
DOI : 10.1016/B978-0-12-460510-7.50017-3
Fast approximate G1 surface blending to support interactive sculptured surface feature design, Product modeling for computer integrated design and manufacture, pp.149-61, 1997. ,
DOI : 10.1007/978-0-387-35187-2_13
Constrained curve fitting on manifolds, Computer-Aided Design, vol.40, issue.1 ,
DOI : 10.1016/j.cad.2007.01.012
Moving a B-spline surface to a curve???a trimmed surface matching algorithm, Computer-Aided Design, vol.29, issue.6, pp.449-55, 1997. ,
DOI : 10.1016/S0010-4485(96)00086-3
The art of computer programming-fundamental algorithms, 1969. ,
Computing a chain of blossoms, with application to products of splines, Computer Aided Geometric Design, vol.11, issue.6, pp.597-620, 1994. ,
DOI : 10.1016/0167-8396(94)90054-X
Curve reconstruction from unorganized points, Computer Aided Geometric Design, vol.17, issue.2, pp.161-77, 2000. ,
DOI : 10.1016/S0167-8396(99)00044-8
An optimal algorithm for expanding the composition of polynomials, ACM Transactions on Graphics, vol.16, issue.2, pp.155-78, 1997. ,
DOI : 10.1145/248210.248221
3D terrain models on the basis of a triangulation, Geowissenschaftliche Mitteilungen, 2002. ,
The NURBS book, 1997. ,
Filling n -sided regions with NURBS patches, The Visual Computer, vol.15, issue.2, pp.77-89, 1999. ,
DOI : 10.1007/s003710050163
Curves on surfaces: Analysis and new solutions Information Geometers, The mathematics of surfaces, pp.57-71, 1998. ,
Exact and approximate computation of B-spline curves on surfaces, Computer-Aided Design, vol.36, issue.4, pp.351-62, 2004. ,
DOI : 10.1016/S0010-4485(03)00100-3
An improved Hoschek intrinsic parametrization, Computer Aided Geometric Design, vol.20, issue.8-9, pp.8-9513, 2003. ,
DOI : 10.1016/j.cagd.2003.06.004
New bounds on the magnitude of the derivative of rational B??zier curves and surfaces, Computer Aided Geometric Design, vol.22, issue.4, pp.321-327, 2005. ,
DOI : 10.1016/j.cagd.2005.01.003
Approximate G1 continuous interpolation of a rectangular network of rational cubic curves, Computer-Aided Design, vol.28, issue.12, pp.1007-1023, 1996. ,
DOI : 10.1016/0010-4485(96)00017-6
Fitting B-spline curves to point clouds by curvature-based squared distance minimization, ACM Transactions on Graphics, vol.25, issue.2, pp.214-252, 2006. ,
DOI : 10.1145/1138450.1138453
Control point adjustment for B-spline curve approximation, Computer-Aided Design, vol.36, issue.7, pp.639-52, 2004. ,
DOI : 10.1016/S0010-4485(03)00140-4
A rational extension of Piegl???s method for filling -sided holes, Computer-Aided Design, vol.38, issue.11, pp.1166-78, 2006. ,
DOI : 10.1016/j.cad.2006.07.001
