A counterexample on point inversion and projection for NURBS curve, Computer Aided Geometric Design, vol.24, issue.5, 2007. ,
DOI : 10.1016/j.cagd.2007.03.008
URL : https://hal.archives-ouvertes.fr/inria-00201817
Improved algebraic algorithm on point projection for Bézier curves, International Multi-Symposiums on Computer and Computational Sciences, vol.17, pp.158-163, 2007. ,
Geometric constraint solver using multivariate rational spline functions, Proceedings of the sixth ACM symposium on Solid modeling and applications , SMA '01, pp.1-10, 2001. ,
DOI : 10.1145/376957.376958
A second order algorithm for orthogonal projection onto curves and surfaces, Computer Aided Geometric Design, vol.22, issue.3, pp.251-260, 2005. ,
DOI : 10.1016/j.cagd.2004.12.001
A framework for efficient minimum distance computations, Proceedings. 1998 IEEE International Conference on Robotics and Automation (Cat. No.98CH36146), pp.3678-3684, 1998. ,
DOI : 10.1109/ROBOT.1998.681403
Geometric algorithms for the intersection of curves and surfaces, Computers & Graphics, vol.19, issue.3, pp.391-403, 1995. ,
DOI : 10.1016/0097-8493(95)00009-2
Fast interference detection between geometric models, The Visual Computer, vol.23, issue.3, pp.542-561, 1995. ,
DOI : 10.1007/BF02434040
Point inversion and projection for NURBS curve and surface: Control polygon approach, Computer Aided Geometric Design, vol.20, issue.2, pp.79-99, 2003. ,
DOI : 10.1016/S0167-8396(03)00021-9
Geometric Modeling, 1985. ,
Shape Interrogation for Computer Aided Design and Manufacturing, 2001. ,
DOI : 10.1007/978-3-642-04074-0
Parametrization for surface fitting in reverse engineering, Computer-Aided Design, vol.33, issue.8, pp.593-603, 2001. ,
DOI : 10.1016/S0010-4485(00)00103-2
Surface Curve Design by Orthogonal Projection of Space Curves Onto Free-Form Surfaces, Journal of Mechanical Design, vol.118, issue.1, pp.42-52, 1996. ,
DOI : 10.1115/1.2826855
Improved algorithms for the projection of points on NURBS curves and surfaces, Computer Aided Geometric Design, vol.23, issue.5, pp.439-445, 2006. ,
DOI : 10.1016/j.cagd.2006.01.007
Computation of stationary points of distance functions, Engineering with Computers, vol.21, issue.8, pp.231-246, 1993. ,
DOI : 10.1007/BF01201903
