A counterexample on point inversion and projection for NURBS curve, Computer Aided Geometric Design, vol.24, issue.5, 2007. ,
DOI : 10.1016/j.cagd.2007.03.008
URL : https://hal.archives-ouvertes.fr/inria-00201817
Distance extrema for spline models using tangent cones, Proceedings of the 2005 Conference on Graphics Interface, pp.169-175, 2005. ,
A second order algorithm for orthogonal projection onto curves and surfaces, Computer Aided Geometric Design, vol.22, issue.3, pp.251-260, 2005. ,
DOI : 10.1016/j.cagd.2004.12.001
Minimum distance between a canal surface and a simple surface, Computer-Aided Design, vol.35, issue.10, pp.871-879, 2003. ,
DOI : 10.1016/S0010-4485(02)00123-9
Point inversion and projection for NURBS curve and surface: Control polygon approach, Computer Aided Geometric Design, vol.20, issue.2, pp.79-99, 2003. ,
DOI : 10.1016/S0167-8396(03)00021-9
Some identities for products and degree raising of splines, Constructive Approximation, vol.1, issue.1, pp.195-208, 1991. ,
DOI : 10.1007/BF01888153
Geometric Modeling, 1985. ,
Parametrization for surface fitting in reverse engineering, Computer-Aided Design, vol.33, issue.8, pp.593-603, 2001. ,
DOI : 10.1016/S0010-4485(00)00103-2
Optimization, Algorithms and Consistent Approximations, 1997. ,
Algorithms with Adaptive Smoothing for Finite Minimax Problems, Journal of Optimization Theory and Applications, vol.14, issue.3, pp.459-484, 2003. ,
DOI : 10.1023/B:JOTA.0000006685.60019.3e
Improved algorithms for the projection of points on NURBS curves and surfaces, Computer Aided Geometric Design, vol.23, issue.5, pp.439-445, 2006. ,
DOI : 10.1016/j.cagd.2006.01.007
Control point adjustment for B-spline curve approximation, Computer-Aided Design, vol.36, issue.7, pp.639-652, 2004. ,
DOI : 10.1016/S0010-4485(03)00140-4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.96.2991
Computation of stationary points of distance functions, Engineering with Computers, vol.21, issue.8, pp.231-246, 1993. ,
DOI : 10.1007/BF01201903
