Intersection Testing between an Ellipsoid and an Algebraic Surface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper presents a new method on the intersection testing problem between an ellipsoid and an algebraic surface. In the new method, the testing problem is turned into a new testing problem whether a univariate polynomial has a positive or negative real root. Examples are shown to illustrate the robustness and efficiency of the new method.
Xiao-DiaoChen2007b.pdf (365.41 Ko) Télécharger le fichier
inria-00518388 , version 1 (17-09-2010)
  • HAL Id : inria-00518388 , version 1
Xiao-Diao Chen, Jun-Hai Yong, Jean-Claude Paul, Jiaguang Sun. Intersection Testing between an Ellipsoid and an Algebraic Surface. Proceedings of the Tenth International Conference on Computer Aided Design and Computer Graphics (CAD-CG'07), School of Electronics Engineering and Computer Science, Peking University, Oct 2007, Beijing, China. ⟨inria-00518388⟩
Collections
INRIA INRIA2
48 Consultations
301 Téléchargements
