-spline curve fitting based on adaptive curve refinement using dominant points, Computer-Aided Design, vol.39, issue.6, pp.439-51, 2007. ,
DOI : 10.1016/j.cad.2006.12.006
URL : https://hal.archives-ouvertes.fr/hal-00458708
Hausdorff and minimal distance between parametric freeforms in R 2 and R 3 In: The 5th international conference of geometric modeling and processing. Lecture notes in computer science, pp.191-204, 2008. ,
Fundamentals of computer aided geometric design, 1993. ,
An error-bounded approximate method for representing planar curves in B-splines, Computer Aided Geometric Design, vol.21, issue.5, pp.479-97, 2004. ,
DOI : 10.1016/j.cagd.2004.03.003
The NURBS book. second ed, 1997. ,
DOI : 10.1007/978-3-642-97385-7
Constrained B-spline curve and surface fitting, Computer-Aided Design, vol.21, issue.10, pp.641-649, 1989. ,
DOI : 10.1016/0010-4485(89)90162-0
Parameter optimization in approximating curves and surfaces to measurement data, Computer Aided Geometric Design, vol.8, issue.4, pp.267-90, 1991. ,
DOI : 10.1016/0167-8396(91)90016-5
Fitting B-spline curves to point clouds by curvature-based squared distance minimization, ACM Transactions on Graphics, vol.25, issue.2, pp.214-252, 2006. ,
DOI : 10.1145/1138450.1138453
Evolution-based least-squares fitting using pythagorean hodograph spline curves, Computer Aided Geometric Design, vol.24, issue.3, pp.310-332, 2007. ,
Point-tangent/point-normal B-spline curve interpolation by geometric algorithms, Computer-Aided Design, vol.41, issue.6, pp.412-434, 2009. ,
DOI : 10.1016/j.cad.2009.02.005
A method for approximate NURBS curve compatibility based on multiple curve refitting, Computer-Aided Design, vol.32, issue.4, pp.237-52, 2000. ,
DOI : 10.1016/S0010-4485(99)00088-3
Constrained curve fitting on manifolds, Computer-Aided Design, vol.40, issue.1, pp.25-34, 2008. ,
Multidimensional curve fitting to unorganized data points by nonlinear minimization, Computer-Aided Design, vol.27, issue.1, pp.48-58, 1995. ,
DOI : 10.1016/0010-4485(95)90752-2
Optimization of a NURBS representation, Computer-Aided Design, vol.25, issue.11, pp.699-710, 1993. ,
DOI : 10.1016/0010-4485(93)90011-C
Constrained interpolation with rational cubics, Computer Aided Geometric Design, vol.20, issue.5, pp.253-75, 2003. ,
DOI : 10.1016/S0167-8396(03)00044-X
A Data-Reduction Strategy for Splines with Applications to the Approximation of Functions and Data, IMA Journal of Numerical Analysis, vol.8, issue.2, pp.185-208, 1988. ,
DOI : 10.1093/imanum/8.2.185
Knot placement for B-spline curve approximation, Report, 1999. ,
Inner point interpolation method with tangent direction constraint for planar curve approximation, Computer Aided Geometric Design, 2010. ,
Geometric Hermite interpolation, Computer Aided Geometric Design, vol.12, issue.6, pp.567-80, 1995. ,
DOI : 10.1016/0167-8396(94)00034-P
An extension algorithm for B-splines by curve unclamping, Computer-Aided Design, vol.34, issue.5, pp.415-424, 2002. ,
DOI : 10.1016/S0010-4485(01)00108-7
High accuracy geometric Hermite interpolation, Computer Aided Geometric Design, vol.4, issue.4, pp.269-78, 1987. ,
DOI : 10.1016/0167-8396(87)90002-1
Geometric Hermite interpolation with maximal order and smoothness, Computer Aided Geometric Design, vol.13, issue.8, pp.681-95, 1996. ,
DOI : 10.1016/0167-8396(96)00004-0
Adaptive knot placement in B-spline curve approximation, Computer-Aided Design, vol.37, issue.8, pp.791-798, 2005. ,
DOI : 10.1016/j.cad.2004.09.008
Fair interpolation and approximation of B-splines by energy minimization and points insertion, Computer-Aided Design, vol.28, issue.9, pp.753-60, 1996. ,
DOI : 10.1016/0010-4485(95)00087-9
Data fitting with a spline using a real-coded genetic algorithm, Computer-Aided Design, vol.35, issue.8, pp.751-60, 2003. ,
DOI : 10.1016/S0010-4485(03)00006-X
A catalog of special plane curves, 1972. ,
