(anti−Ωx × Σz)-based k-set Agreement Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Zohir Bouzid
  • Fonction : Auteur
  • PersonId : 860591
This paper considers the k-set agreement problem in a crash-prone asynchronous message passing system enriched with failure detectors. Two classes of failure detectors have been previously identified as necessary to solve asynchronous k-set agreement: the class anti-leader anti−Ωk and the weak-quorum class Σk. The paper investigates the families of failure detector (anti−Ωx)1xn and (Σz)1zn. It characterizes in an n processes system equipped with failure detectors anti−Ωx and Σz for which values of k, x and z k-set-agreement can be solved. While doing so, the paper (1) disproves previous conjunctures about the weakest failure detector to solve k-set-agreement in the asynchronous message passing model and, (2) introduces the first indulgent algorithm that tolerates a majority of processes failures.
SigmaSA-TR.pdf (279.51 Ko) Télécharger le fichier
inria-00519606 , version 1 (20-09-2010)
  • HAL Id : inria-00519606 , version 1
Zohir Bouzid, Corentin Travers. (anti−Ωx × Σz)-based k-set Agreement Algorithms. [Research Report] ???. 2010, pp.19. ⟨inria-00519606⟩
180 Consultations
79 Téléchargements
