Graph classes : a survey, Society for Industrial and Applied Mathematics, 1999. ,
A new exact method for the two-dimensional orthogonal packing problem, European Journal of Operational Research, vol.183, issue.3, pp.1196-1211, 2007. ,
DOI : 10.1016/j.ejor.2005.12.048
A Combinatorial Characterization of Higher-Dimensional Orthogonal Packing, Mathematics of Operations Research, vol.29, issue.2, pp.353-368, 2004. ,
DOI : 10.1287/moor.1030.0079
A General Framework for Bounds for Higher-Dimensional Orthogonal Packing Problems, Mathematical Methods of Operational Research, vol.60, issue.2, pp.311-329, 2004. ,
DOI : 10.1007/s001860400376
An Exact Algorithm for Higher-Dimensional Orthogonal Packing, Operations Research, vol.55, issue.3, pp.569-587, 2007. ,
DOI : 10.1287/opre.1060.0369
URL : http://arxiv.org/abs/cs/0604045
Computers and Intractability ? A Guide to the Theory of NP- Completeness, 1979. ,
Algorithmic Graph Theory and Perfect Graphs, 1980. ,
Optimal rectangle packing, ICAPS, pp.142-149, 2004. ,
DOI : 10.1007/s10479-008-0463-6
An Incremental Linear-Time Algorithm for Recognizing Interval Graphs, SIAM Journal on Computing, vol.18, issue.1, pp.68-81, 1989. ,
DOI : 10.1137/0218005
An Exact Approach to the Strip-Packing Problem, INFORMS Journal on Computing, vol.15, issue.3, pp.310-319, 2003. ,
DOI : 10.1287/ijoc.15.3.310.16082
Optimal rectangle packing : A meta-csp approach, ICAPS, pp.93-102, 2006. ,
A sat-based method for solving the twodimensional strip packing problem, Proceedings of the 15th RCRA workshop on Experimental Evaluation of Algorithms for Solving Problems with Combinatorial Explosion, 2008. ,
