An analysis of lower bound procedures for the bin packing problem, Computers & Operations Research, vol.32, issue.3, pp.395-405, 2005. ,
DOI : 10.1016/S0305-0548(03)00244-2
The steel mill slab design problem revisited. CP'AI'OR-08, pp.377-381, 2008. ,
Capacitated Vehicle Routing on Trees, Operations Research, vol.39, issue.4, pp.616-622, 1991. ,
DOI : 10.1287/opre.39.4.616
Lower bounds and reduction procedures for the bin packing problem, Discrete Applied Mathematics, vol.28, issue.1, pp.59-70, 1990. ,
DOI : 10.1016/0166-218X(90)90094-S
A global constraint for bin-packing with precedences : Application to the assembly line balancing problem, Proceedings of the Twenty-Third AAAI Conference on Artificial Intelligence, pp.369-374, 2008. ,
Scalable Load Balancing in Nurse to Patient Assignment Problems, 6th International Conference Integration of AI and OR Techniques in Constraint Programming for Combinatorial Optimization Problems (CPAIOR), 2009. ,
DOI : 10.1007/978-3-642-01929-6_19
Data of assembly line balancing problems, p.93 ,
Bison: A fast hybrid procedure for exactly solving the one-dimensional bin packing problem, Computers & Operations Research, vol.24, issue.7, pp.627-645, 1997. ,
DOI : 10.1016/S0305-0548(96)00082-2
A constraint for bin packing. Principles and Practice of Constraint Programming -CP, pp.648-662, 2004. ,
