Consistency restoration and explanations in dynamic CSPs???Application to configuration, Artificial Intelligence, vol.135, issue.1-2, pp.199-234, 2002. ,
DOI : 10.1016/S0004-3702(01)00162-X
Arc consistency for soft constraints, Artificial Intelligence, vol.154, issue.1-2, pp.199-227, 2004. ,
DOI : 10.1016/j.artint.2003.09.002
Problem solving with the atms, Artificial Intelligence, vol.28, issue.2, pp.197-224, 1986. ,
Explanation-based generalisation of failures, ECAI, pp.339-344, 1988. ,
Uncertainty in constraint satisfaction problems: A probabilistic approach, ECS- QARU, pp.97-104, 1993. ,
DOI : 10.1007/BFb0028188
Consistency-based diagnosis of configuration??knowledge bases, Artificial Intelligence, vol.152, issue.2, pp.213-234, 2004. ,
DOI : 10.1016/S0004-3702(03)00117-6
Interactive configuration using constraint satisfaction techniques, PACT-96, pp.37-44, 1996. ,
Dynamic constraint satisfaction problems, AAAI, pp.25-32, 1990. ,
Vehicle sales configuration : the cluster tree approach, ECAI'02 Configuration Workshop, 2002. ,
Configuration as composite constraint satisfaction, AI and Manufacturing Research Planning Workshop, pp.153-161, 1996. ,
Possibilistic Constraint Satisfaction Problems or ???How to handle soft constraints????, UAI, pp.268-275, 1992. ,
DOI : 10.1016/B978-1-4832-8287-9.50041-4
URL : http://arxiv.org/abs/1303.5427
Arc Consistency for Soft Constraints, CP, pp.411-424, 2000. ,
DOI : 10.1007/3-540-45349-0_30
URL : http://arxiv.org/abs/cs/0111038
SAT v CSP, CP, pp.441-456, 2000. ,
DOI : 10.1007/3-540-45349-0_32
Stochastic constraint programming, ECAI, pp.111-115, 2002. ,
