Preprints, Working Papers, ...
On semi-Classical Questions Related to Signal Analysis
Taous-Meriem Laleg-Kirati 1, * Bernard Helffer 2
* Corresponding author
1 Magique 3D - Advanced 3D Numerical Modeling in Geophysics
LMAP - Laboratoire de Mathématiques et de leurs Applications [Pau], Inria Bordeaux - Sud-Ouest
Abstract : This study explores the reconstruction of a signal using spectral quantities associated with some self-adjoint realization of an h-dependent Schrödinger operator when the parameter h tends to 0. Theoretical results in semi-classical analysis are proved. Some numerical results are also presented. We first consider as a toy model the sech^2 function. Then we study a real signal given by arterial blood pressure measurements. This approach seems to be very promising in signal analysis. Indeed it provides new spectral quantities that can give relevant information on some signals as it is the case for arterial blood pressure signal.
Complete list of metadatas
https://hal.inria.fr/inria-00520773
Contributor : Taous-Meriem Laleg-Kirati <>
Submitted on : Friday, September 24, 2010 - 11:04:15 AM
Last modification on : Tuesday, February 2, 2021 - 2:54:03 PM
Long-term archiving on: : Saturday, December 25, 2010 - 2:48:12 AM
HelfferANDLaleg.pdf
Identifiers
  • HAL Id : inria-00520773, version 1
  • ARXIV : 1009.5372
Citation
Taous-Meriem Laleg-Kirati, Bernard Helffer. On semi-Classical Questions Related to Signal Analysis. 2010. ⟨inria-00520773v1⟩
Share
Metrics
Record views
26
Files downloads
39
