Realistic Simulation of Seasonal Variant Maples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue 2nd International Symposium on Plant Growth Modeling, Simulation, Visualization and Applications Année : 2006
This paper presents a biologically-motivated system of seasonal variant scenes generation for maples, which has a obvious leaf color transformation during the time. Given climate data and knowledge on environmental influence to maples, our system is able to simulate this seasonal leaf color transformation process. Our system consists of three steps: environment configuration, climate influence simulation and leaf texture acquisition. The first step decides the general color change timing of the maple tree based on its local environment. Then we make further adjustments to the timing determined in the last step taking into account the influence of climate in the specific case. In the last step, the texture maps of leaves are generated based on the pigment information. Our system is also able to simulate the seasonal color variance of other trees by adjusting related parameters.
MapleSimulation.pdf (488.78 Ko) Télécharger le fichier
inria-00521833 , version 1 (28-09-2010)
  • HAL Id : inria-00521833 , version 1
  • PRODINRA : 247236
Ning Zhou, Weiming Dong, Xing Mei. Realistic Simulation of Seasonal Variant Maples. 2nd International Symposium on Plant Growth Modeling, Simulation, Visualization and Applications, 2006. ⟨inria-00521833⟩
146 Consultations
284 Téléchargements
