Nonsmooth Modeling and Simulation for Switched Circuits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2010
Nonsmooth Modeling and Simulation for Switched Circuits concerns the modeling and the numerical simulation of switched circuits with the nonsmooth dynamical systems (NSDS) approach, using piecewise-linear and multivalued models of electronic devices like diodes, transistors, switches. Numerous examples (ranging from introductory academic circuits to various types of power converters) are analyzed and many simulation results obtained with the INRIA open-source SICONOS software package are presented. Comparisons with SPICE and hybrid methods demonstrate the power of the NSDS approach. Nonsmooth Modeling and Simulation for Switched Circuits is intended to researchers and engineers in the field of circuits simulation and design, but may also attract applied mathematicians interested by the numerical analysis for nonsmooth dynamical systems, as well as researchers from Systems and Control.
inria-00522358 , version 1 (30-09-2010)
Vincent Acary, Olivier Bonnefon, Bernard Brogliato. Nonsmooth Modeling and Simulation for Switched Circuits. Springer Verlag, 69, 2010, Lecture Notes in Electrical Engineering, 9789048196807. ⟨10.1007/978-90-481-9681-4⟩. ⟨inria-00522358⟩
Relations
241 Consultations
0 Téléchargements
