Topology-reducing surface simplification using a discrete solid representation, ACM Transactions on Graphics, vol.21, issue.2, pp.88-105, 2002. ,
DOI : 10.1145/508357.508359
Optimizing the topological and combinatorial complexity of isosurfaces, Computer-Aided Design, vol.37, issue.8, pp.847-857, 2005. ,
DOI : 10.1016/j.cad.2004.09.013
Error-Bounded Simplification of Topologically-Complex Assemblies, pp.355-366, 2003. ,
ReMESH: An Interactive Environment to Edit and Repair Triangle Meshes, IEEE International Conference on Shape Modeling and Applications 2006 (SMI'06), pp.271-276 ,
DOI : 10.1109/SMI.2006.29
A lightweight approach to repairing digitized polygon meshes. The Visual, Computer, vol.26, 2010. ,
RSVP: a geometric toolkit for controlled repair of solid models, IEEE Transactions on Visualization and Computer Graphics, vol.4, issue.2, pp.162-177, 1998. ,
DOI : 10.1109/2945.694983
Isosurface reconstruction with topology control, 10th Pacific Conference on Computer Graphics and Applications, 2002. Proceedings., pp.246-255, 2002. ,
DOI : 10.1109/PCCGA.2002.1167868
Structure Preserving CAD Model Repair, Computer Graphics Forum, vol.18, issue.2, pp.527-536, 2005. ,
DOI : 10.1111/j.1467-8659.2005.00878.x
Automatic restoration of polygon models, ACM Transactions on Graphics, vol.24, issue.4, pp.1332-1352, 2005. ,
DOI : 10.1145/1095878.1095883
Progressive gap closing for mesh repairing Advances in Modelling, Animation and Rendering, pp.201-213, 2002. ,
Geometric modeling based on polygonal meshes, ACM SIGGRAPH 2007 courses on, SIGGRAPH '07 ,
DOI : 10.1145/1281500.1281640
URL : https://hal.archives-ouvertes.fr/inria-00337991
Exact and Robust (Self-)Intersections for Polygonal Meshes, Computer Graphics Forum, vol.28, issue.3, 2010. ,
DOI : 10.1111/j.1467-8659.2009.01609.x
Marching Cubes 33: construction of topologically correct isosurfaces, 1995. ,
Introduction to algorithms, 2001. ,
Filling holes in complex surfaces using volumetric diffusion, Proceedings. First International Symposium on 3D Data Processing Visualization and Transmission, pp.428-438, 2002. ,
DOI : 10.1109/TDPVT.2002.1024098
Computing homology groups of simplicial complexes in R3, Journal of the ACM, vol.45, issue.2, pp.266-287, 1998. ,
DOI : 10.1145/274787.274810
Single-pass GPU solid voxelization for real-time applications, Proceedings of Graphics Interface, pp.73-80, 2008. ,
Topology simplification for polygonal virtual environments, IEEE Transactions on Visualization and Computer Graphics, vol.4, issue.2, pp.133-144, 1998. ,
DOI : 10.1109/2945.694955
Approximation of a Variable Density Cloud of Points by Shrinking a Discrete Membrane, Computer Graphics Forum, vol.21, issue.4, pp.791-807, 2005. ,
DOI : 10.1111/1467-8659.00474
Bilateral mesh denoising, ACM Transactions on Graphics, vol.22, issue.3, pp.950-953, 2003. ,
DOI : 10.1145/882262.882368
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.3578
Computing Betti Numbers via Combinatorial Laplacians, Algorithmica, vol.21, issue.4, pp.331-346, 1998. ,
DOI : 10.1007/PL00009218
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.527.4556
Cutting and stitching: converting sets of polygons to manifold surfaces, IEEE Transactions on Visualization and Computer Graphics, vol.7, issue.2, pp.136-151, 2001. ,
DOI : 10.1109/2945.928166
Topological noise removal, Proceedings of Graphics Interface, pp.19-26, 2001. ,
Complete Polygonal Scene Voxelization, Journal of Graphics Tools, vol.4, issue.4, pp.27-41, 2002. ,
DOI : 10.1080/10867651.2002.10487563
Robust repair of polygonal models, ACM Transactions on Graphics, vol.23, issue.3, pp.888-895, 2004. ,
DOI : 10.1145/1015706.1015815
Fixing Geometric Errors on Polygonal Models: A Survey, Journal of Computer Science and Technology, vol.26, issue.3, pp.19-29, 2009. ,
DOI : 10.1007/s11390-009-9206-7
Editing the topology of 3D models by sketching, ACM Transactions on Graphics, vol.26, issue.3, p.42, 2007. ,
DOI : 10.1145/1276377.1276430
An Efficient Algorithm for Topologically Correct Segmentation of the Cortical Sheet in Anatomical MR Volumes, NeuroImage, vol.14, issue.2, pp.329-346, 2001. ,
DOI : 10.1006/nimg.2001.0831
A partial mesh replacement technique for design modification in rapid prototyping, Computers & Industrial Engineering, vol.58, issue.3, 2009. ,
DOI : 10.1016/j.cie.2009.11.007
Holes and Genus of 2D and 3D Digital Images, CVGIP: Graphical Models and Image Processing, vol.55, issue.1, pp.20-47, 1993. ,
DOI : 10.1006/cgip.1993.1002
On surface reconstruction: A priority driven approach, Computer-Aided Design, vol.41, issue.9, pp.626-640, 2009. ,
DOI : 10.1016/j.cad.2009.04.006
Filling holes in meshes, Proceedings of the Eurographics, pp.200-205, 2003. ,
Marching cubes: A high resolution 3D surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.163-170, 1987. ,
DOI : 10.1145/37402.37422
Consistent solid and boundary representations from arbitrary polygonal data, Proceedings of the 1997 symposium on Interactive 3D graphics , SI3D '97, pp.155-162, 1997. ,
DOI : 10.1145/253284.253326
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.163.7621
Simplification and repair of polygonal models using volumetric techniques, IEEE Transactions on Visualization and Computer Graphics, vol.9, issue.2, pp.191-205, 2003. ,
DOI : 10.1109/TVCG.2003.1196006
Discovering structural regularity in 3D geometry, ACM Transactions on Graphics (SIGGRAPH Proceedings), vol.27, issue.3, 2008. ,
Atomic volumes for mesh completion, Proceedings of the Eurographics, pp.33-42, 2005. ,
The Marching Intersections algorithm for merging range images, The Visual Computer, vol.20, issue.2-3, pp.149-164, 2004. ,
DOI : 10.1007/s00371-003-0237-8
Matchmaker, Proceedings of the fifth ACM symposium on Solid modeling and applications , SMA '99, pp.31-41, 1999. ,
DOI : 10.1145/304012.304016
Context-based surface completion, ACM Transactions on Graphics, vol.23, issue.3, pp.878-887, 2004. ,
DOI : 10.1145/1015706.1015814
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.411.369
Inpainting surface holes, Proceedings 2003 International Conference on Image Processing (Cat. No.03CH37429), pp.903-909, 2003. ,
DOI : 10.1109/ICIP.2003.1246828
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.2884
Removing excess topology from isosurfaces, ACM Transactions on Graphics, vol.23, issue.2, pp.190-208, 2004. ,
DOI : 10.1145/990002.990007
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1032.8661
TransforMesh : A Topology-Adaptive Mesh-Based Approach to Surface Evolution, Proceedings of the Asian Conference on Computer Vision, pp.166-175, 2007. ,
DOI : 10.1007/978-3-540-76390-1_17
URL : https://hal.archives-ouvertes.fr/inria-00590245
Topology Repair of Solid Models Using Skeletons, IEEE Transactions on Visualization and Computer Graphics, vol.13, issue.4, pp.675-685, 2007. ,
DOI : 10.1109/TVCG.2007.1015
