Performance Analysis of SNMP in OLSRv2-routed MANETs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Mobile Ad Hoc NETworks (MANETs) are generally thought of as infrastructure-less and largely "un-managed", capable of accommodating highly dynamic network topologies. Yet, while the network may be un-managed, monitoring performance and setting configuration parameters post-deployment, remains important in order to ensure proper ''tuning'' and maintenance of a MANET. While SNMP is sometimes considered too ''heavy'' for MANETs -- a too chatty a protocol with too large protocol messages -- it remains the predominant management and monitoring protocol in the Internet, and many implementations exist. This \articleformat analyzes SNMP in an OLSRv2-routed MANET, with the purpose of investigating performance metrics, such as delivery ratio, delay, management overhead, collisions and performance monitoring accuracy. In order to address concerns both regarding SNMP being "heavy", as well as regarding the accuracy of performance reports obtained via SNMP polling in MANETs, where path delays can be highly variable, the utility of performance reporting proxies, i.e. the REPORT-MIB, is studied. The obtained results show that a significant benefit can be obtained by so deploying performance reporting proxies in an SNMP managed MANET. The investigations are supported by way of network simulations (NS2).
Lorsquon parle de réseaux mobiles ad-hoc (MANETs), on pense généralement à des réseaux sans infrastructure et à des déploiements en réseaux largement non-gérés, pouvant s'adapter à des topologies de réseau très changeantes. Néanmoins, bien que l'infrastructure du réseau est de nature non-gérée, la surveillance des performances du réseau et le choix des paramètres de configuration une fois le réseau déployé demeurent primordiaux pour la maintenance et le réglage fin d'un réseau MANET. Alors que SNMP est parfois considéré trop "lourd" pour des MANETs, il demeure le protocole prédominant de management et monitorage d'Internet, et beaucoup implémentations du protocole existent. Ce rapport analyse SNMP dans des MANETs basés sur OLSRv2, avec l'intention de déterminer des métriques de performance, comme le taux de remise, délai, overhead et collisions dans le simulateur de réseaux NS2.
RR-7407.pdf (713.13 Ko) Télécharger le fichier
inria-00523607 , version 1 (05-10-2010)
inria-00523607 , version 2 (12-07-2011)
  • HAL Id : inria-00523607 , version 2
Robert Cole, Ulrich Herberg. Performance Analysis of SNMP in OLSRv2-routed MANETs. [Research Report] RR-7407, INRIA. 2011, pp.22. ⟨inria-00523607v2⟩
239 Consultations
407 Téléchargements
