SnoopIB: Interval-based event specification and detection for active databases, Data & Knowledge Engineering, vol.59, issue.1, pp.139-165, 2006. ,
DOI : 10.1016/j.datak.2005.07.009
SecSip: A stateful firewall for SIP-based networks, 2009 IFIP/IEEE International Symposium on Integrated Network Management, pp.172-179, 2009. ,
DOI : 10.1109/INM.2009.5188807
URL : https://hal.archives-ouvertes.fr/inria-00404853
VeTo: An exploit prevention language from known vulnerabilities in SIP services, 2010 IEEE Network Operations and Management Symposium, NOMS 2010, pp.216-223, 2010. ,
DOI : 10.1109/NOMS.2010.5488464
URL : https://hal.archives-ouvertes.fr/inria-00544976
Better Error handling when parsing rules When changing the configuration using the SOAP interface while SecSip is running, it is possible to submit a faulty configuration , and the engine converting rulespecs to rules might hit an error, and stop in the middle of the process, leaving "holes" in the firewall. We would need to add a temporary rulespec repository, to which the running config is copied before the new one is imported, and that SecSip can revert to if an error is found ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès ,
