New interface
Conference papers
Hierarchical node replication attacks detection in wireless sensors networks
Wassim Znaidi 1 Marine Minier 1 Stéphane Ubéda 2
1 SWING - Smart Wireless Networking
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
2 AMAZONES - Ambient Middleware Architectures: Service-Oriented, Networked, Efficient and Secured
Abstract : Wireless sensor networks (WSNs) are composed of a large number of low-cost, low-power, and multi-functional sensor nodes that communicate at short distance through wireless links. They are usually deployed in an open and uncontrolled environment where attackers may be present. Due to the use of low-cost materials, hardware components are not tamper-resistant and an adversary could access a sensor's internal state. An adversary can easily capture even a single node and inserts duplicated nodes at any location in the network. If no specific detection mechanisms are established, the attacker could lead many insidious attacks such as subverting data aggregation protocols by injecting false data, revoking legitimate nodes and disconnecting the network if the replicated nodes are judiciously placed at chosen locations. In this paper, we propose a hierarchical distributed algorithm for detecting node replication attacks using a Bloom filter mechanism and a cluster head selection, we also introduce the adequate network replies in case of detection. We also present simulation results for random topologies and show that our algorithm is able to detect replication attacks in all cases.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00524354
Contributor : Marine Minier Connect in order to contact the contributor
Submitted on : Thursday, October 7, 2010 - 4:27:46 PM
Last modification on : Friday, February 4, 2022 - 3:08:47 AM
Identifiers
Collections
Citation
Wassim Znaidi, Marine Minier, Stéphane Ubéda. Hierarchical node replication attacks detection in wireless sensors networks. Personal, Indoor and Mobile Radio Communications, 2009 IEEE 20th International Symposium on, IEEE, Sep 2009, Tokyo, Japan. pp.82 - 86, ⟨10.1109/PIMRC.2009.5450196⟩. ⟨inria-00524354⟩
Share
Metrics
Record views
99
