Closed-form Solutions and Degenerate Cases for Camera Calibration with One-Dimensional Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Camera calibration with one-dimensional objects is based on an algebraic constraint on the image of the absolute conic. We give an alternative derivation to this constraint, allowing a geometrical interpretation. From this, we derive the degenerate cases, or critical motions, where the calibration algorithm fails. We also show that constraints on the intrinsic parameters lead to simplified closed-form solutions and a reduced set of critical motions. A simulation and a real data experiment is performed to evaluate the accuracy of the calibration result for motions close to being critical.
HammarstedtSturmHeyden-iccv05.pdf (744.32 Ko) Télécharger le fichier
inria-00524397 , version 1 (25-05-2011)
Pär Hammarstedt, Peter Sturm, Anders Heyden. Closed-form Solutions and Degenerate Cases for Camera Calibration with One-Dimensional Objects. 10th International Conference on Computer Vision (ICCV '05), Oct 2005, Beijing, China. pp.317-324, ⟨10.1109/ICCV.2005.68⟩. ⟨inria-00524397⟩
161 Consultations
367 Téléchargements
