New interface
Conference papers
Calibrage itératif de caméras à partir de scènes planes
Frédéric Jurie 1 Eric Noirfalise 2 Peter Sturm 3
1 image
LASMEA - Laboratoire des sciences et matériaux pour l'électronique et d'automatique
3 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : We present a method for camera autocalibration from images of an unknown planar object. The few existing methods for that problem proceed by non-linear batch optimization, whereas our method is of sequential nature, being based on Kalman filtering. Its overall computational cost is much smaller, thus enabling the use of video sequences as input for real-time, on-the-fly, autocalibration. Being able to use video efficiently is very beneficial, since a stable autocalibration requires images taken with significantly varying camera orientations : batch methods put limits on the number of images used, hence require either to select key frames from a video, or to use discrete image sequences, for which the matching is more difficult. Our method is not concerned by these issues. Although not optimal (in the bundle adjustment sense), our method compensates by using indeed all available information in an image sequence. Experimental results show that it performs similarly to a global batch method, in terms of accuracy and convergence, while allowing real-time autocalibration in practice.
Document type :
Conference papers
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/inria-00524413
Contributor : Peter Sturm Connect in order to contact the contributor
Submitted on : Wednesday, May 25, 2011 - 2:47:18 PM
Last modification on : Friday, February 4, 2022 - 3:08:52 AM
Long-term archiving on: : Friday, August 26, 2011 - 2:22:04 AM
File
04_RFIA_calib.pdf
Identifiers
  • HAL Id : inria-00524413, version 1
Collections
Citation
Frédéric Jurie, Eric Noirfalise, Peter Sturm. Calibrage itératif de caméras à partir de scènes planes. 14ème Congrès AFCET de Reconnaissance des Formes et Intelligence Artificielle, Jan 2004, Toulouse, France. pp.261-269. ⟨inria-00524413⟩
Share
Metrics
Record views
180
Files downloads
169
