HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Curvilinear structures segmentation in fluoroscopic images
Abstract : Fluroscopic imaging provides means to asses the motion of the internal structures and therefore is of great use during surgery. In this report we propose a novel bottom-up approach for the segmentation of curvilinear structures in these images. The main challenge to be addressed is the lack of visual support due to the low SNR where traditional ridge-based methods fail. Our approach combines machine learning techniques, unsupervised clustering and linear programming / discrete optimization. In particular, numerous invariant to position/rotation classifiers are combined to detect candidates pixels of curvilinear structures. These candidates are grouped into consistent geometric segments through the use of a state-of-the art unsupervised clustering algorithm. The complete curvilinear structure is obtained through a linking of these segments using the elastica model in a linear programming framework in a first variant, and using discrete optimization in a second one. Very promising results were obtained on angioplasty guide wire segmentation in cardiac interventional images.
Document type :
Reports
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/inria-00524911
Contributor : Nicolas Honnorat Connect in order to contact the contributor
Submitted on : Sunday, October 24, 2010 - 7:00:20 AM
Last modification on : Friday, January 21, 2022 - 3:01:26 AM
Long-term archiving on: : Tuesday, January 25, 2011 - 2:21:02 AM
File
RR-7414.pdf
Identifiers
  • HAL Id : inria-00524911, version 1
Collections
Citation
Nicolas Honnorat, Régis Vaillant, Nikolaos Paragios. Curvilinear structures segmentation in fluoroscopic images. [Research Report] RR-7414, INRIA. 2010. ⟨inria-00524911⟩
Share
Metrics
Record views
171
Files downloads
97
