Tutorial: Using the UML profile for MARTE to MPSoC co-design dedicated to signal processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper demonstrates the use of a model driven design flow for Multiprocessor System on chips (MPSoCs) such as those dedicated to intensive signal processing applications. The most intensive part of these applications is usually composed of systematic signal processing followed by intensive data processing. The systematic signal processing mainly consists of a chain of filters and regular processing applied on the input signals independently of the signal values. It results in a characterization of the input signals with values of interest. The intensive data processing applies irregular computations on these values of interest. Those computations may depend on the signal values. Examples of these applications are Software Radio Receiver, Sonar Beam Forming and Multimedia video codes.
GaspardDoc-JFMA.pdf (340.51 Ko) Télécharger le fichier
inria-00525012 , version 1 (10-10-2010)
  • HAL Id : inria-00525012 , version 1
Imran Rafiq Quadri, Abdoulaye Gamatié, Jean-Luc Dekeyser. Tutorial: Using the UML profile for MARTE to MPSoC co-design dedicated to signal processing. Colloque International Télécom'2009 & 6èmes JFMMA, Mar 2009, Agadir, Morocco. ⟨inria-00525012⟩
142 Consultations
192 Téléchargements
