Reports
A Resilience Approach to High-Performance Workflows
Toan Nguyen 1 Laurentiu Trifan 1
1 OPALE - Optimization and control, numerical algorithms and integration of complex multidiscipline systems governed by PDE
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
Abstract : This report presents an approach to design, implement and deploy resilient distributed workflows. It supports the smooth integration of existing software for simulation applications, e.g. Matlab, Scilab, Python, OpenFOAM, Paraview and application programs. The contribution of the report is a new feature which supports resilience, i.e., application-level fault-tolerance and exception-handling. Connections with exascale computing requirements are also made. An overview of a prototype implementation based on the YAWL workflow management system is given.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/inria-00526291
Contributor : Toan Nguyen Connect in order to contact the contributor
Submitted on : Thursday, October 14, 2010 - 5:24:43 PM
Last modification on : Friday, August 5, 2022 - 3:50:55 AM
Long-term archiving on: : Saturday, January 15, 2011 - 2:43:31 AM
File
RR-7421.pdf
Identifiers
  • HAL Id : inria-00526291, version 1
Citation
Toan Nguyen, Laurentiu Trifan. A Resilience Approach to High-Performance Workflows. [Research Report] RR-7421, INRIA. 2010, pp.17. ⟨inria-00526291⟩
Share
Metrics
Record views
153
Files downloads
192
