Combining Satisfiability Procedures for Unions of Theories with a Shared Counting Operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fundamenta Informaticae Année : 2010
We present some decidability results for the universal fragment of theories modeling data structures and endowed with arithmetic constraints. More precisely, all the theories taken into account extend a theory that constrains the function symbol for the successor. A general decision procedure is obtained, by devising an appropriate calculus based on superposition. Moreover, we derive a decidability result for the combination of the considered theories for data structures and some fragments of arithmetic by applying a general combination schema for theories sharing a common subtheory. The effectiveness of the resulting algorithm is ensured by using the proposed calculus and a careful adaptation of standard methods for reasoning about arithmetic, such as Gauss elimination, Fourier-Motzkin elimination and Groebner bases computation.
Fichier non déposé
inria-00526683 , version 1 (15-10-2010)
Enrica Nicolini, Christophe Ringeissen, Michael Rusinowitch. Combining Satisfiability Procedures for Unions of Theories with a Shared Counting Operator. Fundamenta Informaticae, 2010, 105 (1-2), pp.163--187. ⟨10.3233/FI-2010-362⟩. ⟨inria-00526683⟩
111 Consultations
0 Téléchargements
